audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
I think somebody made a pcb design of the latest schematic.
No, it for http://www.electronics-lab.com/projects/power/003/index.htmlIs it for this one: http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=7317.0;attach=16065;image
And do you have better resolution?
Like the original project, the values for R4 and R10 are wrong and R10 connects to the wrong voltage.dejan5rovic said:Please tell me what you think and how can I make it better without changing OPamp.
I need about 20V DC output, and around 2,5 Amps for my testings.
The latest modifications use easy-to-find MC34071 or TLE2141 opamps that have inputs and outputs that work at 0V with a single polarity supply. Their max allowed supply is 44V. But a low voltage negative supply is needed because the output of U3 must go negative enough (about -0.7V) to allow D9 to force the output of the project to 0V when the output is shorted.I'm in the process of deciding on a design for a lab power supply, and this one seems to fit the needs that I have. However, I have been reading some of the forum replies and I have a question. Why are you guys using OP amps that aren't rail to rail? If you used a rail to rail amp, it would eliminate the need for the charge pump negative voltage generator and make life a whole lot easier. Am I just missing something, or is there a reason for using non-rail to rail OP amps?
Dan
