audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
The 2N3055 is an emitter-follower without voltage gain. Its dropout voltage might be only 2V. Because it has no voltage gain then the stability (possible oscillations) of opamp U2 is not affected.Hey,
couldn't you replace the 2n3055 with an MJ2955? This would reduce the dropout voltage ... like this:
http://www.elektronik-kompendium.de/public/schaerer/kdarl2.htm
What do you think?
Using a PNP common-emitter transistor adds voltage gain which might cause U2 to oscillate.
Our project uses a fast opamp and a fast driver transistor for good transient response. Your circuit uses an extremely slow LM358 opamp and the same driver as our circuit so it might have a slow transient response.
You do not gain much but try it and let us know if it works.
