Rich Grise said:
That works because the transmission line is less than 0.01 wavelength.
So impedance matching becomes moot. If the speaker line were 1/4
wavelength
long, there would be almost no signal transferred at all.
Cheers!
Rich
There is nothing wrong with driving a transmission line/antenna from a zero
impedance source. It does NOT change the SWR. The point is that an audio
amplifier with a damping factor of 50 is NOT conjugate matched.
Somebody mentioned Motorola Application note 721. This is what it says:
" ..the load, in first approximation, is not related to the device, except
for VCE(sat). The load value is primarily dictated by the required output
power and the peak voltage; it is not matched to the output impedance of the
device. "
When device people talk about "matching", they mean matching the load to
what the transistor wants to see, which is not the conjugate of the output
impedance. The way this is done is to build an amplifier, and vary the load
until maximum output power is reached. The transistor is then removed, and
the impedance looking into the coupling network is measured. The conjugate
of this is sometimes listed as "output impedance" on data sheets. Newer data
sheets will have an asterisk * next to that, and a note explaining what it
means. If you look at Philips literature, you will see exactly the same
explanation.
This whole thing has been hashed out here about 5 times during the past
year.
Tam
