thanx audio guru. but sorry, some more questions;
1. does every power mosfet have the zener diode connected internally across their source to drain pins?
2. when using the cd4047 and cd 4001 ic for a simple msw inverter as done by kachew, what frequencies would be found at the output pins 10,11, and 13 respectively for an inverter of 50hz?
3.does the source to drain voltage(vds) matter when choosing power mosfets for inverter designs of supply voltages of between 24v and 48v?
4. can thyristors be used to substitute power mosfets in higher power inverter designs?
