kachew said:
Can i know how much the current will flow to turn on the mosfet for switchin?
The gate of a Mosfet is a capacitor. It needs current to charge and discharge quickly. For the low mains frequency the peak gate current of a few milliamps will be fine.
if i wan to get an output for 150W but not 600W but using the same circuit can it make it? as i know if i buy a smaller transformer as i asked the shopkeeper, the battery which supply 50A to the transformer which is 10A will blow the transformer off....can i know wat is the amps input will go to the transfomer?
The battery supplies 50A to the circuit only if the load on the inverter is 500W. The current from the battery and through the Mosfets and transformer is less when the load draws less power. Without a load then the current is only one or two amps.
A 150W load on an inverter will use about 188W from the battery. Then the current from a 12V battery through the Mosfets and into the transformer is 188/12= 15.7A.
A 10A transformer will be overloaded.
How can i calculate the output current of the transformer.
Calculate the transformer's output current I= P/V. I= 150W/230V. It is only 0.65A.
...i still cant get what u mean by previous post....
1) This simple inverter has a square-wave output. It is not a smooth sine-wave like the mains.
2) Many electronic devices need a sine-wave input. A sine-wave has a peak voltage that is 1.414 times higher than a square-wave that has the same average power. The power supply of an electronic device charges its main filter capacitor to the peak voltage that is higher with a sine-wave. Then the electronic device won't work properly with the lower peak voltage from a square-wave.
3) Transformers are designed for a sine-wave input. A square-wave has many high frequency harmonics that create extra heat in a transformer.
