19V 2.6A Monitor Ok To Run 3.16A Power Pack?
stan_s2
Nov 20, 2013
10
Hi all, im wondering if the 19V 3.16A power adapter that I got with my LCD Monitor will cause any troubles etc or shorten the monitors lifespan as their is an extra 0.56A running to the monitor. The Monitor is rated for 19V 2.6A power on DC.
OLIVE2222
Oct 2, 2011
690
Hi stan_s2,
The extra 0.56A will not run to the monitor but instead the monitor will consume the needed curent (maximum 2.6 Amps here). No issue at all, just ensure that both connectors have same polarity (pinout) !!
regards,
Olivier
Do 100 W light bulbs pop when you plug them into the same socket that can power a 1000 W toaster?
stan_s2
Nov 20, 2013
10
Hi stan_s2,
regards,
Olivier
Olive2222 how do i check both connectors have the same polarity pinout?
OLIVE2222
Oct 2, 2011
690
Stan, look carefully for a plus or minus sign on the connectors itself or on the power pack label. you can also check on the monitor jack or on is label.
regards,
Olivier
stan_s2
Nov 20, 2013
10
its round...
stan_s2
Nov 20, 2013
10
regards,
Olivier
its round... see image in my post above please
14,486
do you have a multimeter ?
of so in DC volts and a range that is higher than 19V
check the inner and outer connectors of the plug and determine which one is negative and which is positive
OLIVE2222
Oct 2, 2011
690
Also it's seems to be engraved on the monitor just above the jack (a close-up pic of this area can help)
Olivier
stan_s2
Nov 20, 2013
10
Olivier
it just says DC above plug which is engraved... its a circle plug, goes in one way and that's in... attached is the power brick and the sticker on the back...
Go to this page and take a look at the polarity symbols.
Look for them either near the socket or on the body of the brick
stan_s2
Nov 20, 2013
10
Why do i need to look this up? There is only one way for the monitor to be plugged into the brick as it is just a circle... and the power brick is a 3 pin that only goes in one way as the centre pin is raised
You don't need to look it up. Just plug in the other adapter. If you see smoke or smell a nasty burning smell, THEN you can look it up and find out if that was the reason
14,486
one really wonders why we bother to give good advice some times :rolleyes:
stan_s2
Nov 20, 2013
10
ok and if its been running for 6+ hours non stop, then it must be connected in the correct polarity and is receiving enough and the correct voltage and amperage?
If it works it's fine. From what you've told us the new adapter can supply more current than the old one.
However if you go willy nilly plugging in adapters without checking their polarity you are likely to make a potentially expensive mistake one day.
There is a simple way to check, but you've resisted us telling you what it is.
Congratulations on coming up with the empty chamber this time.
stan_s2
Nov 20, 2013
10
ok, please tell me the simple check with images
