19v 5A PSu
Xenobius1
May 28, 2004
103
Hello, I would like to build my own Laptop Psu because the original one broke. Could somone kindly enough point me to a Circuit of a Fixed PSU which gives me 19v @ 5A ??
ALSO since a PWM Power Supply does not heat up that much, is it good for a Laptop??
thanks a lot
PS.. Speaking of PWM.. I have a motor which takes 24v @ 14A. Does anyone have a circuit to controll such a motor?? the supply of this motor is two large batteries with 12v each in series.
Thanks a lot.
Xenobius
ante1
Jan 24, 2004
4,138
Hi Xenobius,
It’s not easy to design a SMPSU, are you sure you don’t want to try to repair the old one first?
About the motor; is it suppose to run in one direction only or must it reverse too?
Xenobius1
May 28, 2004
103
Thanks for the reply buddy.
It should run only in one direction. and it i a DC Motor. Power is already supplied (2 large batteries) also when I connect them, it gives a hell of a kick start.
thanks a lot
ante1
Jan 24, 2004
4,138
A simple 555 PWM circuit with couple of MOSfets will do the job.
Xenobius1
May 28, 2004
103
Could you kindly send me a link to a schematic that will do the job for the motor please?
thanks dude!
ante1
Jan 24, 2004
4,138
Hi Dude  ;D
First from this site: http://www.electronics-lab.com/projects/motor_light/003/ with a bigger MOSFET and a good heatsink this one will work fine.
And here is another one which is made for 12V but could easily be modified: http://www3.telus.net/chemelec/Projects/PWM/PWM.htm
And one more: http://home.att.net/~wzmicro/3525.html
Xenobius1
May 28, 2004
103
THANKS dude! Will give them a look and let you know  ;)
sorry took me some time to reply.. vb project giving me a head ache  :p
