John Barrett
- Jan 1, 1970
- 0
Genome said:Ermmmmm...... Current sense transformers, something like
http://www.cd4power.com/data/magnetics/kmp_5600.pdf
Each PFC section needs to control its own inductor current otherwise they
won't share the total load. It's tied up with the volt-second balance,
inductors integrate the voltage placed accross them as the current through
them. If there is a mismatch in the drive to the inductors then one of
them will hog the current.
The local current error amplifiers force them to share it but you need
separate sense signals for each stage so one honking big current sensing
thing on the input won't do. You also need a reasonable frequency response
from the devices if you want to compensate the current loops correctly.
Ahaaaa, LT1248, shows you how crap I am for not checking if they did one
or if LTSpice had the model. I knew they did but there is something wrong
with my head. I suppose I'm fixated on TI because I grew up with Unitrode.
It's all much of a muchness and once you get happy with one you can see
that a lot of the internals are the same in all the others.
hehehe not suprising -- now if I could get the reference design from the
datasheet to model -- I'd be in hog heaven
If you really really need to ground the output of your beast....... Uhm,
right, your side of the pond has strange electricity with something like
110V balanced either side of ground. My head hurts but I think you might
only get away with it if you use half wave rectification which is going to
be dirty and waste half of the capacity of your supply.
our 220v is really a pair of 120v lines 180 out of phase, when you plug into
a 120 socket, the "nuetral" side is pretty much power company ground
so sticking a full wave bridge on it directly gets you half wave pulses
I dont REALLY need earth ground referenced, but it would make some other
issues I have to deal with one HECK of a lot easier
Trying to avoid iron as much as possible, and I see what you mean about painSince you seem to enjoy pain you might as well go the whole banana and
dangle a transformer isolated coverter of the end of your PFC stages.
Something like a half or full bridge. That will make any (well most)
concerns about earth disappear.
I've been trying off and on for 24+ hours now to get a pos->pos boost to
work side by side with a neg->pos boost with a shared ground tied to power
company ground (modeled as 2 120v sources, 180 phased, with neg sides tied
to ground, pos sides feeding a full bridge and splitting the pos and neg to
the 2 boost modules.
I'm getting close -- not using full PFC yet -- just a fixed gate pulse to
see where things are going.. and I'm getting fairly stable output, but have
one major weird thing going on.... HV spikes showing up on the rectified
input to the positive boost that need to go away ... they start on the
falling edge of the input voltage pulse, continue through zero and into the
begining of the next pulse, with a particularly hard spike as the input
voltage bottoms out and starts back up. its got to be the inductor causing
it somehow since it is being switched on the other side by the mosfet to
ground, so maybe the PFC will make it go away. If you dont think that will
help, I'd love to hear what it might be -- Spice simalation available on
request
Other than that -- its behaving as well as can be expected since I havent
fine tuned any of the component values yet, and am still using a spice
switch instead of a FET or IGBT.... once all that is done, I'll pack it up
in a subckt and start on the PFC controller and stuffing enough of these in
parallel to handle my load requirements
