Looking for 60A 60V mosfet
Fish4Fun
So long, and Thanks for all the Fish!
Aug 27, 2013
481
@asaf123098
OK, you can stop your search for a mosfet/transistor.
You will all most certainly be better off using a simple mechanical switch to interrupt the signal source to the speed controller.
If you will simply post a link to the ESC (Electronic Speed Controller) you are using (and if the signal source to the ESC is NOT embedded with the ESC, then a link to whatever device you are using as an input signal to the ESC) , I feel confident someone here will be able to help you achieve a satisfactory means to disable the motor w/o attempting to actively switch 3.6kW.
Cheers!
Fish
asaf123098
May 23, 2017
12
Rather difficult trying to decipher just what it is exactly that you need.
Best approach is sketch up a diagram and others can go from there.
I think i over complicated it, i basically
need a switch that can take on 60v and 60a..
For that im looking for a mosfet as i thought its the best solution.
Then how do you come to the conclusion in your 1st post?
You mean how did i know they dont work ?
What speed controller are you using?
Does it have an enable input?
If so, that can likely be used as kill switch.
Bertus
I am using this vesc.
As far as i know, some vescs do have an enable input, i couldn't find any info for that with my vesc..
@asaf123098
Cheers!
Fish
As mentioned above, im using a vesc, your idea about the signal input switch is possible as the signal input isn't embedded.
But im looking for that 3.6kw switch because i don't want anything connected to power when the switch is off.. i i have some regulators and leds on the board, so i figured the best way is to just place a mosfet on the main output from the battery, and just "kill" everything with one click.
Im basically trying to copy one of these
14,317
You don't need a dedicated enable input. Just interrupt the pwm signal and ensure that without an active pwm signal a the control input the motor controller is in the off state (e.g. by adding a pull-down resistor from the control input to 0V).
If you don't want to buy one of these, why not simply use the transistors that are used in these: NVMFS5C628NL aas stated on the website you linked?
asaf123098
May 23, 2017
12
Sorry for the long time to reply,
That actually a great idea, unfortunately i could not find as a through hole, do you think it will be possible to solder it that way ?
