Hi All,
Let me open by explaining that I am a novice when it comes to troubleshooting failed electrical appliances/components.
That said, this is my first time posting and I'm looking forward to whatever assistance folks are able to provide.
I am the owner (and original installer) of a no-longer-supported c.1998 Tamarack Technologies Inc. "HV500" Whole House Cooler (a.k.a "high efficiency attic fan") which, sadly, has ceased operating. The unit consists of a power relay, a synchronous motor (which is connected to two countering rotating pusher arms that, when operated, open and close the insulated hatch and actuate two limit switches, one of which cuts power to the hatch motor and sends power to the fan while the other of which, I believe, cuts power to the power relay to shut everything off), the aforementioned limit switches and the aforecited fan, all housed in a custom two-piece molded plastic (I'm guessing PVC) enclosure. Note: the above supplied links point to the currently available replacement components and don't necessarily detail the currently installed components. For instance, the synchronous motor currently installed in the unit was long ago discontinued which prevented me from supplying a link to it (so I supplied a link to the modern-day comparable part).
Having removed the unit from the attic, disassembled it, cleaned it, researched the availability of replacement components and done my best to test the existing components (all of which, I might add, are readily available off-the-shelf analog parts) I have determined the following:
As I recall, the way that this unit is supposed to operate is that when the wall-mounted switch is toggled to the "on" position, the power relay energizes thus sending power to the synchronous motor which then activates to open the insulated hatch (the action of which, in the first second or two of operation, results in the de-actuation of one of the two limit switches, what I'll call Limit Switch "A"). When the hatch reaches the open position, the other limit switch (what I'll call Limit Switch "B") is actuated which simultaneously cuts power to the hatch motor while also sending power to the fan, the latter of which turns on [and cools our two story house via chimney effect - by drawing cooler outdoor air in through open windows and doors (which we open around dusk) - and also by pressurizing the attic (which causes hot air in the attic to be evacuated though the vents in each gable end]. Then, when the wall-mounted switch is toggled to the "off" position, the fan immediately shuts off (not sure what the power relay does in this moment) and the synchronous motor re-activates, this time closing the insulated hatch (the action of which, in the first second or two of operation, results in the deactivation of Limit Switch "B"). When the hatch reaches the closed position, this action, via the position of the pusher arms, results in the actuation of Limit Switch "A", the latter of which must then cut power to the power relay, thus removing power from the entirety of the unit. What I can't work out is exactly how Limit Switch "B" is able to force the power relay to cut power to the fan and synchronous motor, etc. but then allows the power relay to re-energize when the wall mounted switch is toggled back to the 'on" position.
Anyways, my question is: which - in terms of the existing components - do I need to replace? Without understanding the related PFM, it seems obvious that the synchronous motor needs to be replaced. However, do I also need to replace the power relay and/or one or both of the limit switches? The only component that makes any sense to me (again, as a novice) is the fan. When I power it up on its own, it works fine - so, I'm guessing that it doesn't need to be replaced. Does the power relay "sense" the problem with the synchronous motor and, accordingly, not send power to it? Is it "smart" enough to be able to function in this way? If so, do I only, therefore, need to replace the synchronous motor in order to return this unit to fully operable status?
Hoping someone with a better handle on the world of electricity and analog components can help me troubleshoot this (very effective and very much missed) appliance.
Thanks, in advance, for your kind assistance.
And, because a photo is worth a thousand words, please see the following images (Note: the Wago Lever Nuts are my addition - I upgraded from the original wire nuts - and the scary-looking makeshift test-bed power supply cord was unplugged while I took pictures):
- when everything is connected and the hatch in the 'closed' position (which results in one pusher arm pressing on one of the two limit switches) and I send power to the power relay, it actuates but nothing else happens;
- when everything is connected and the hatch is the 'open' position (which results in one pusher arm pressing on the other of the two limit switches) and I send power to the power relay, it actuates but nothing else happens;
- the fan, when isolated from the rest of the unit's electrical system and supplied independently with power, runs normally;
- the synchronous motor, when isolated from the rest of the unit's electrical system and supplied independently with power, runs but no longer has enough strength, via the 1RPM reduction gearbox (which I opened and all the nylon gears are in place and in excellent condition), to drive the interconnected pusher arms. IOW the motor runs but is not strong enough to oppose the weight of the hatch. However, if I lay the unit on its side (thus unloading the gravitational weight of the hatch from the motor) the motor is able to actuate the pusher arms and the hatch opens and closes.
- Both limit switches show continuity (or not depending on the position of the limit switch) implying to me that they are both functioning properly.
