230v Transformer, 115v input.
Divedeep
Feb 2, 2014
57
I have a question that i would like to run past you.
I have a device that uses a 230v PCB mounted transformer. EL30 casing.
The transformer has 2 pin for input, live and neutral, and has 2 outputs, 12v each.
I would like to allow this device to work in the USA which uses 115v. Can anyone see a problem with using a 230v transformer with 2 x 24v outputs. As i would be supplying half the voltage then i would get half the voltage at the output, giving me the 2 x 12v outputs.
Is there anything wrong with this approach?
hevans1944
Hop - AC8NS
Jun 21, 2012
4,984
Applying half the primary voltage to a transformer with a 240 VAC-rated primary will work, and the secondary voltages will be halved, but the transformer may not be able to deliver its rated current to the secondary windings.
Colin Mitchell
Aug 31, 2014
1,416
"may not be able to deliver its rated current to the secondary windings."
I do not see why not.
Tha fios agaibh
Aug 11, 2014
2,253
I agree, theoretically it could draw twice the current at the lower voltage without exceeding the va rating of the transformer.
Also, USA household voltage is 120v and running at 60hz. (Your xformer is 50hz?) But should still be about half.
