2x tip31 and stereo female 3,5 mm jack
Anon_41854
is this correct, i am newbie and i was wondering if this is even correct and how to connect female audio jack does pin 3 connect to GND or -.
Thanks in advance
have a nice day:)
14,487
Hi Gregor
welcome to EP :)
no, that circuit isn't going to work
Reverse ALL your LEDs
Anon_41854
Thanks, ok i will reverse them, my skill in electricity is on primary school level, but i was allways fascinated by that stuff so i bought myself soldering iron and sturted with something :) and now i want to do something more complex so here i am ;)
i replaced audi jack with 2 rca connectors for right and left channel. Is this right?
And if connection from rca goes to GND or - on battery?
14,487
the RCA grounds need to go to the battery negative
and remove the GND from that switch leave that side of the switch unconnected
Martaine2005
May 12, 2015
5,318
To add to what Dave said,
These "instructables" should be called "destructibles"... They are a menace..
You will damage your amp. It's not 'if', it's 'when'...
I also notice that you are using RCA's. I can only assume that you will plugging directly to an amp output.
You might want to consider putting a diode across base and emitter to stop the negative ac killing the transistor and may be your output too.
I would also consider a base and led current limiting resistor.
These circuits only work with high volume. There are much better and safer circuits to use with your audio / computer equipment.
Martin
Anon_41854
thanks for replay and giving solution. I did add base resistors and LED resistors then i added diodes between base and emitter and added resistor between emitters and deleted switch. will buy one housing for battery with switch. Hope this is somewhat correct :)
Martaine2005
May 12, 2015
5,318
The diodes now need reversing.
You shouldn't need the resistor across the emitters.
Depending how bright they get, you might need to change the led resistor. Maybe 150 or 200 Ohms.
Martin.
Anon_41854
Ok, thanks, i will reverse the diodes and put variable resistor on leds and delete resistor between emitters. Then i hope i will be able to create board in eagle and send gerber to manufacturer. i will post myresuslts :)
Thanks again
Have a nice day
Martaine2005
May 12, 2015
5,318
I wouldn't do anything like that for this!!
You need to breadboard the circuit first and test it...
Or vero-board if soldering is preferable..
You may even be able to use a smaller cheaper transistor! It's only 5 leds..
Also note that they only 'kind of' flash to the volume being high!
Martin
Anon_41854
hi,
ok i will test it and hope it works, but i will probably order board cus i am getting familiar with eagle and stuff, board will be cheap in china there is one sidedd pcb few buks :) as far as resistor go i have plenty .. Bulk order :)
Question about trim resistor how to wire it? do i wire it between 2 pins (middle and left or right) and leave one side pin empty or ..?
Martaine2005
May 12, 2015
5,318
It would depend on the trim pot.
For the small rectangular pots with the adjustment screw, I would connect the screw side to the centre wiper and the other to the circuit.
Anon_41854
hi,
i get it, i just order few leds and when i get them i will test.
One more queston which diode i put between base and emitter?
Thanks for your help
Have a nice day
AnalogKid
Jun 10, 2015
3,058
The diode *across* the base and emitter can be just about anything - 1N4002-4007, 1N914/1N41478, etc.
ak
Anon_41854
hello
i have few 1N4148 at home, so it shold be fine.
Gregor
