300W Resistive load?
JosephKK
Maybe two or three electric irons in parallel.
If this will be anything other than a temporary lashup,
you'll want a fuse rated to interrupt 200VDC.
A typical electric clothes iron (flatiron for those that remember) is
about 450 W rated, with a bang-bang temperature controller.
JosephKK
Small electric heater with switch able power level.
I don't know about now, but in the distant past hardware stores sold
heating elements that screwed into porcelain light sockets. The
intended use was for chicken incubators.
John Ferrell W8CCW
I have actually seen those sold for room heaters (with dish reflector)
at powers a high as 1000 W.
JosephKK
Finned heat sinks, arranged as a square tunnel, fins inward, file,
mill, whatever so they fit together nicely, and the "square" is
muffin-fan size... which fits on one end.
...Jim Thompson
Yup. Also works fine with pairs and any air blocker to make a tunnel.
There will be a thermal gradient along the tunnel, with FETs this
works in your favor though.
JosephKK
If you use transistors that can handle 200V (or way more) like I did
there is no problem.
Plus it allows for all kinds of interesting test scenarios.
N
Nico Coesel
Grant said:
But not up at 200V? Low voltage, high current is easy, transistor
SOA at high voltage not so easy?
I still fail to see why it wouldn't work. The only failure mode I can
think of is the case in which the emitter resistors are too small to
divide the load properly at low currents / high voltages.
Grant
Not saying it cannot work, but you'd need big expensive transistors
to make an active load for 200V at hundreds of watts.
I'm working on a power DAC at the moment, only going up to about 30V
and 30A, non-trivial when you want the same circuit to hold to the
output to nearest mV or mA ;)
First version with transistors leaked and drifted too much, current
version being designed & built with MOSFET switched resistor banks
and analog power amp to make up the small stuff seems far more viable.
But here I'm drifting OT as I'm making a precision load, not a simple
test load, but that explains why my focus is more on the reliability
of an active load.
Recently I built a 1A current sink, while it didn't fail, it was
cooking a power MOSFET on large heatsink, but without fan, at
only 30W. So I pulled the plug at 20 hours operation. Then
realised I could use a bridge circuit instead of accurate current
sink. Side stepped a problem, finding a better solution :) I
ordered $5 worth of precision resistors 10:1 ratio.
Grant.
Tim Williams
