556 dual timing circuits trouble
guitarplayer598
Feb 25, 2012
I need some help with a 556 circuit. I am trying to build a circuit to move a motor in one direction for a few seconds (switch in up position) and a whole different circuit to move the same motor in the opposite direction for a different amount of time (switch in down position). So I wired it all up and soldered it together but one circuit is completely dead and the other is continuously on, I tested it after i soldered it with LED's and one LED never comes on and the other stays on. So my first question in my troubleshooting is can I wire all grounds together for both circuits to one wire? also can I do the same for the power wires. Will this cause trouble?
14,484
hi
welcome to the forums :)
lets see the circuit diagram of what you built
some one may be able to point out any obvious errors :)
or offer suggestions on other alternatives
cheers
guitarplayer598
Feb 25, 2012
Here is the schematic I jotted down quickly sorry it's a bit sloppy.
Thanks in head of time
  • 556 schematic.pdf
twister
Feb 12, 2012
172
Try removing the 4.7k resistor and place a .01 capacitor on the trigger to ground. I believe that I've had more trouble with 555s than any other circuit. I still have some 555n that I can't get to work properly.
