7 Segment LED Counter, Need help!
Mukhalled
Aug 17, 2004
137
I tried to simulate this circuit http://www.electronics-lab.com/projects/misc/012/index.html in Multisim, should pin 14 (count in) be connected to a 5V or GND or ...?
Can you help me please  ;D
AN920
May 15, 2005
359
Connect that to your input pulse you want to count. It won't count on its own. The count pulse must be a logic level input
audioguru2
Apr 6, 2004
12,022
Hi Mukhalled,
I haven't used old TTL ICs for many years and I have lost my TTL Cookbook.
The datasheet for the 74LS90 shows an inverting clock input pin 14, so I think it counts each time it goes low.
Mukhalled
Aug 17, 2004
137
i connect pin 14 to pulse generator (1Hz, 10Vp-p), but it doesn't count... i think there is something wrong in the circuit i connect in Multisim.
Mukhalled
Aug 17, 2004
137
audioguru said:
Hi Mukhalled,
Yes, i think so too that it should count when it goes low. But it doesn't in the simulating program  ???
AN920
May 15, 2005
359
That part model (7447) in Multisim is known to be faulty over a few issues. Even in the latest release it is still not working. They never bothered to fix it. Use a 74HC4543 or 4543 to get it working
Mukhalled
Aug 17, 2004
137
Thanks to inform me about the 7447, i didn't find 4543 in multisim so i used 4511 instead (but changed the display to "commen cathode" instead) and finally it's working now ... Thanks again
