A Control circuit's Vcc
BlackMelon
Aug 7, 2012
189
I'm working on a boost converter. In the case that the input voltage is so high such as 100V, I can't find a way to supply my microcontroller's vcc. Is there any efficient method to do so? (Except putting an additional source for my microcontroller)
BlackMelon
14,317
Cross out "Except".
If your controller's current consumption is very low, you may get away with a linear regulator, otherwise use a step-down regulator.
GPG
Sep 18, 2015
452
BlackMelon
Is your micro driving the converter Show circuit so far.
Minder
Apr 24, 2015
3,561
I have done it from 240vdc using a resistor, Zener and Capacitor.
The current demand is very small and usually fairly constant.
M.
AnalogKid
Jun 10, 2015
3,058
1. Is the boost converter isolated or non-isolated?
2. If the input can be up to 100 V, what is the output voltage and current?
ak
BlackMelon
Aug 7, 2012
189
M.
Could you show me your circuit please?
ak
It's non-isolated converter. The output voltage will be 220*(square_root_of 2) Vdc.
I, however, think of capacitors as in the attached picture. Will this work or not?
AnalogKid
Jun 10, 2015
3,058
No. Your basic thought is correct - the DC voltage will distribute itself across the capacitors in direct proportion to each capacitor's charge. Note that low cost electrolytic capacitors have very poor tolerances, such as -20% to +100 %, so the voltage distribution will be very uneven.
BUT it won't work because capacitors can not pass DC to the regulator.
ak
