Latching relays in a control circuit
DogBark
Jun 11, 2026
10
Hi, im hoping someone can help- I wish to design what I thought would be a simple circuit but it turns out it isnt so easy
I wish to control 2 contactors- say C1 and C2. C1 is a NO and its default state will be that its coul is energised. C2 is a NC and its default state will be for the coil to be deenergised. On the sending of a 240v signal I want c1 to drop out for 10 seconds, and in the middle if that 10 seconds c2 should be energised. C2 will then remail energised when c1 returns to its original state of being energised.
Then, when the 240v signal disappears, I want c1 to again drop out for 10 seconds and in the middle of that period for c2 to be deenergised. C1 then returns to its default state.
I wish to do this without resorting to a plc- but is it possible?
TIA
Minder
Apr 24, 2015
3,561
Look into a SmartRelay there are several makes, they are a 'Poor mans PLC' !;)
Minder
Apr 24, 2015
3,561
I like Schnieder but there are a few choices out there, just compare the specs and functions
DogBark
Jun 11, 2026
10
crutschow
May 7, 2021
991
It can be done with some simple logic circuits if you are up to building that.
What are the relay-coil voltage and current requirements?
danadak
Feb 19, 2021
1,104
A basic simple approach to a multi triggerable timer, using GUI block programming.
DogBark
Jun 11, 2026
10
I think
Hmmm this looks like it can solve my problem perfectly, thank you.
There is a lot of terms in that article which re unfamiliar to me- so here goes I down another series if rabbit holes on a Saturday night !
DogBark
Jun 11, 2026
10
I think i can work out the logic circuits ok, but i am an electrician rather than an electronics engineer so I dont even know where to start in terms of sourcing the right software/interface which would allow me to take electrical signals and process them via logic then output back again as electrical signals.
Have you any advice?
Minder
Apr 24, 2015
3,561
This is where the Smart Relay can come in, as it is programmed in relay logic, see the tutoriols out there, the zelio video can show it.
"Program Zelio Smart Relay Function A Timer in Ladder Logic"
danadak
Feb 19, 2021
1,104
I think
Let me know what terms in article you need further explanation in.
DogBark
Jun 11, 2026
10
Thank you, I really appreciate your help, I have something that is tripping out a seperat, critical piece of equipment in a business every day and it is having a financial effect so i really need to find this solution to just make it switch off/on while it is isolated from the rest of the system
DogBark
Jun 11, 2026
10
My question was whether you could wire and solder the parts on a vector board if given the circuit schematic and the parts required?
Yes I could solder, and could source a vector board, and i am more than willing to purchase whatever components and software is required and to spend the time necessary to construct the solution
DogBark
Jun 11, 2026
10
Thanks for continuing to engage with me- I really appreciate the help, i presume that the terms I will list are all software programs and actions that can be performed within the software
pulse streams of desired width and inter
pulse delay.
A trigger from an A/D value or a pin state.
compound qualified triggers.
And or frequency/pulsewith input qualifiers.
the ATTINY85
8 pin mini dip,
Can run on UNO, Nano and the like boards.
IDE is mBlock 5.0, freebee.
mBlock,
Arduino
Minder
Apr 24, 2015
3,561
I would recomend the Vero strip board, there is a free design/layout pgm VeeCAD.
danadak
Feb 19, 2021
1,104
pulse delay.
Pulses are outputs to a pin to initiate an action like turn on a fan or light. So I make
a pin go high to turn something on, wait for a time delay I set, then make pin go low
to deactivate that specific task/job/event.
Yes, using blocks you decide what triggers a pulse (a logic level to turn something on),
its width (how long pin stays high to keep something on, and once your setting for time
expires to turn it off).
You can initiate the pulse with a trigger. That can be a pin, button, sensor input. Also the
processor has an A to D converter, and you can trigger off its measured V, like a T
sensor, or a resistance measurement.
You can initiate the pulse to turn something on with a combination of triggers, like if switch is
closed AND T is > 100 degrees then turn on a fan, or light or whatever.
And or frequency/pulsewidth input qualifiers.
Say you are measuring a motor shaft RPM, which is a frequency in effect. Or have processor
look at how long something else has turned on, basically its pulse width or time a switch has
been closed, to generate a pulse. Or think frequency AC line disappears so do something with that.
the ATTINY85
8 pin mini dip,
A atmega/arduino type processor.
mBlock is the programming tool you use to program in blocks and when done it
converts the blocks to Atmega/Arduino code and you then click a button to
program that into the board. IDE = Integrated Development Environment, the tool
one uses to develop code and debug it and program into chips/boards.
mBlock,
Arduino
Arduino is an IDE and another tool you can use to program Arduino type boards.
And many others.
Note these boards and chips cannot drive big loads, like fans, motors, high power
leds, servos, whatever. You take the pulse output of the pin activated by program
and feed that to a relay or SSR (Solid State Relay) or a MOSFET or Power Transistor.
So you can do simple things, like one trigger to generate a pulse to a pin, keep the pin on
for your desired time, then turn it off. Or a complex sequence, Like turn on a fan, then wait
until a T trigger is met, turn pin off , the wait until a frequency is met and do something with that.
And start even more tasks.....
Simple program example :
The Nano board (~$4) excellent to start with, then for some projects just use the 8 pin minidip.
DogBark
Jun 11, 2026
10
Thank you, i see an Arduino starter kit on amazon, im going to buy it straight away.
