A resistor at 150°C...how?
  • Thread starter Francesco Piantedosi
  • Start date
Spehro Pefhany
Given the limited budget, I wonder if it would be possible to
derive the temperature from the resistance of the nichrome wire.
It all depends on the tempco of the wire, of course. Just a thought.
Yes, although NiCr is designed to have a relatively low tempco, and
usually controlling the heater temperature itself is a particularly
crummy approach from a controls pov.
Best regards,
Spehro Pefhany
John Larkin
Minco makes flexprint stick-on things that are simultaneously heaters
and sensors. Of course, they only sense their own temperature, not the
temp of the thing they're stuck to, so there's a coupling error. You'd
have the same problem heating air... the heater itself will be hotter
than the exit air stream.
John
John Fields
