a transistor is a variable resistor
Status
Not open for further replies.
bertus
3,882
@dragon , You could have a look here to learn the basics of electronics:
Also the following books might help.
For absolute beginners this might be reasonable:
For more understanding of components have a look at this book:
Bertus
AnalogKid
Jun 10, 2015
3,058
the resistance gets cancelled out.
I understand what you are trying to say, but the way you are saying it is incorrect.
In DC and AC circuits, "cancelling out" something is a specific action, and that action is not what you are describing. A power supply does not cancel anything. However, adjusting the output voltage of a supply, or going from one supply to two supplies in series, can compensate for the consequences that increasing the impedance of an element in a loop has on the value of the current through the loop.
Is there a way you can get a variable resistor with just passive components?
Try this:
Is there a way, using nothing but passive components around a single bipolar transistor, to create a circuit that behaves as a voltage-variable resistance?
No.
With an analog multiplier?
Yes
ak
willsonwanda
Dec 13, 2022
5
Yes, a transistor is like a variable resistor, in that the resistance between collector-emitter or drain-source is variable. It's like a valve, and either allows current to flow or blocks it from flowing.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Sorry! I mean current controlled variable resistor. :)
A thermistor is a current-controlled variable resistor: you send current through a thermistor and it gets hot and its resistance either increases or decreases. Any resistor whose resistance is a function of its temperature can also be considered a current-controlled variable resistor. And resistors are of course passive components.
Another device you might be interested in showing your ignorance about is the parametric amplifier. Go Google and noodle on that before disturbing us with any more of your stupid comments. Maybe you can model a parametric amplifier with your Falstad simulator...
crutschow
May 7, 2021
991
I think that you are being too loose with the terminology.
The usual meaning for a current (or voltage) controlled device is that a current or voltage is controlling separate, but not necessarily isolated parameter.
I would call a thermistor a temperature controlled resistor (since it's not a function of just current).
dragon
Oct 31, 2022
248
You can get these things called VCR's voltage controlled resistors.
but I think I wont be needing them, series connecting power supplies should do it along the "flow line"
14,317
Read here:
A voltage-controlled resistor (VCR) is a three-terminal active device
Just because the device is named "resistor" doesn't mean it actually is on. So sorry, no pasive device here.
bertus
3,882
A VDR is a voltage DEPENDEND resistor. Nowerdays they are called MOV.
Bertus
Status
