Do I need to create a special circuit to adapt a 200ma output to a 30ma input...
And can I use an adapter with a positive ground plug spliced backward to make it a negative ground feed line?
ie.
I have a 200ma adapter with > positive + ---o )--- - negativeI need a 30ma adapter with > negative - ---o )--- + positive
Is a 350ma adapter to large for my delicate roland tr-505 drumachine that uses a
PSA-120 that has 9v 30mA on the case?
I have a negative ground 9v 350ma, if I can't use the positive ground.
The adapter that came with the device, doesn't have the voltage or amps on it, maybe the boss psa-120s and 120t are the right ones, and I should just buy a new one?
(the new psa-120 comes with T and S options, and are of a higher milliamperage, and this worries me... I don't want to ruin my roland)
ie.
