sorry, I don't know your mean. can you draw a circuit to me, thanks!!!audioguru said:I think the base of the oscillator should be modulated then it can connect to a common-emitter LED driver transistor.
An oscilloscope will show you what the transmitter is doing.
No, ever since I heard how wonderful FM broadcasts sound, I gave up with the narrow-band, distorted and full-of-interference sound of AM broadcasts.SM2GXN said:By the way audioguru, have ever tried to simulate an AM circuit in switchercad?
two resistors?audioguru said:Your IR receiver probably has a strong output at 38kHz now but you can't hear a frequency so high. Therefore the receiver needs to feed an AM detector diode and filter to recover the modulation.
The transmitter circuit has two very important resistors that need adjustment. See my sketch.
You are using Amplitude Modulation. Noise is fluctuations in amplitude that the circuit is designed to receive. You should be using FM instead, for low noise.
Sorry, I forgot to attach my sketch. The resistors are boxed in red.ryanleung said:two resistors?
Yes. Your receiver circuit needs one. View attachment 38859the AM detector means the envelope detector?
The two resistors that I boxed with red in my receiver circuit reduces the gain. They should be adjusted so that the circuit doesn't overload with too much signal.ryanleung said:should I amplify the signal again?(tansmitter and receiver)
Yes, the capacitive reactance of a 0,1uF capacitor is about 40 ohms at 38kHz, but which resistor and which capacitor?ryanleung said:The resistor is 40ohm and the capacitor is 0.1uF. The frequency is 38kHz.
Is it right?
f=1/(2*pi*R*C)
