Hi MP,
Math? But I can't find my old slide-rule!
I'm glad that you agree that Sasi's relay turns-off his circuit, because my new-fangled calculator tells me that a 150A/hr car battery will power the maximum leakage current (25uA each at 55V) of the six MOSFETs for more than 116 years!
Maybe Sasi needs backup only for the short time for his hard-drive to park, and uses just a string of 4A/hr D-cell Ni-Cads. They will power that "parasitic" leakage for more than 3 years!
I think that the little solar-cell (a real one, not just a label) on my calculator can supply the 150uA of leakage current. ;D
Hi Sasi,
Your PCB layouts are very nice. You should post a complete project.
Time for you to get a new slide rule. If environmental and meteorological equipment was built upon the same assumptions, the industry would be a mess. I never disagreed that the relay would turn off his power. He still has resistance to ground. If you look at the components as resistors, and note that you have six in parallel with only looking at the transistors, you can use thevinen's theorem and see that you have enough parasitic draw to draw down the battery after sitting for some time. Good design practise always isolates the battery on equipment when it is not in use. This is a standard.
I only metioned it as a courtesy to sasi, since he could use a DPDT relay and take care of this also. Quite frankly, if you guys want to ignore good design practice, it does not bother me a bit. Just don't deny that it is a better design to isolate the battery from the electronics when it is not in use....and at the cost of only one section of the relay!
..and since I am on the subject of design, the circuit could use a method of charging the battery. The availability is there but not used. There should be a step down from the mains and a regulator to keep the battery up when the mains are giving the available power. Even with no draw, the battery will not stay up if not used for long periods. It will need to be charged. This is just a start. This circuit, if used only for emergency back-up, will also need a way to put a load on the battery once in a while and then charge it. An idle battery will not last long. I do not see much long term usefulness for this circuit "as is". Perhaps as a project, it could be considered a building block for something more involved.
MP
