audioguru2
- Apr 6, 2004
- 12,026
- Joined
- Apr 6, 2004
- Messages
- 12,026
Hi Alun,
You must keep the Q high on a tuned transformer for it to continue to ring at the reonant frequency and convert a square-wave to a sine-wave. Therefore a load ruins it.
I was thinking of hitting the tuned circuit with a brief pulse of the proper direction at zero crossings and the voltage will build to infinity without a load.
There is a lot of discussion on the web about the pros and cons of ferroresonant transformers also called a CVT (constant voltage transformer). They convert a 15% change in voltage at the primary to a 3% change at the output. They are said to hum badly, heat-up with a low input voltage and a high one and slowly reduce their output when the input is cutoff (blowing-up SMPS).
You could probably use one with a push-pull inverter drive and get a reasonable sine-wave out.
