K
[email protected]
- Jan 1, 1970
- 0
Romex is a brand name. Not all brands of cable have the paper. It's
not intended as insulation, it is there to make it easier to strip the
outer jacket without damaging the insulation on each wire. You make a
cut next to the ground wire, then pull it to the side till the tear is
long enough. Then use dikes or an electrician's knife to trim the
unwanted jacket. The brands without the paper are cheaper, but require
more time to prep, and sometimes the outer jacket is stuck to the
insulation on the wires, which wastes a lot of time to carefully peel
them apart.
I have a pair of 12/14 AWG strippers that cut the outer as well as
inner insulation (one pass for each). Basically, it just nicks the
outer insulation, all the way around. Then you just pull the end and
the outer insulation just slides off on the paper (sometimes the paper
is left but usually not). They're great for electrical work (I'm just
doing my basement now - 50-60 duplex outlets and a couple of dozen
light fixtures).
