Any help in PCB Wizard without item
Barrymons
Jul 25, 2013
3
Hi all
Does any one know how i can add a component in PCB Wizard. My schematic is finished but I need to add the component L298 dual full bridge driver but the component cannot be found in the library, I tried adding a component but failed, If any one can shed some light on this issue I would be very grateful.
Thank you
14,317
Sorry, I can't help directly. Indirectly you could use any other component with the same layout/geometry and connect it as required into your schematic to be able to do the artwork. The schematic will look awkward and unintelligible, but at least you can continue working while you are on the lookout for the correct library element.
