SniffTheGlove
- Dec 22, 2016
- 9
- Joined
- Dec 22, 2016
- Messages
- 9
I have been trying to create a simple project but I am stuck. I have tried asking for help in the Arduino Community Forums but all I get is responses of "Why do you want to do this" or "Don't use that, use this" or just cryptic responses that just confuse the hell out of me, so I am trying here for advice.
There several online tutorials you are shown how to create charge/voltage detectors using a couple of BC547 that drive an LED to show the charge etc being detected by an antenna. See the schematic here
So the level of brightness of the LED reflects the detected charge.
Now I would like to insert an arduino into the schematic so I am able to measure the strength of the detected charge so I can record the data and save to an SD Card.
Now this is where I can not get it to all work., so lets pretend I have an Arduino Uno and a breadboard (with the above schematic laid out).
The breadboard is feed by power from the Uno, along with the negative. Now where would I put the Analog (A5) Arduino connection to measure the detected charge or do I need to add something else.
I have tried to add A5 to the last BC547 base pin, and the emitter pin all without luck of getting a reading on A5 of the Uno
