Arduino Nano + RGB led + adxl335
mollekake
Jun 30, 2014
37
Hello!
So i've been fidling around with my arduino, a rgb led and an accelerometer.
I've tried out some tap detection, and got it to work, and decided i wanted to do something with it.
So i hooked up an RGB led, and am trying to make it change color for each tap.
The tap detection works, but the led colors are all wrong :S
Here is my code:
Code:
// these constants describe the pins. They won't change:
const int xpin = A2;                  // x-axis of the accelerometer
const int ypin = A3;                  // y-axis
const int zpin = A4;                  // z-axis (only on 3-axis models)
const int red = 9;
const int green = 10;
const int blue = 11;
//int sampleDelay = 50;   //number of milliseconds between readings
void setup()
  // initialize the serial communications:
  Serial.begin(9600);
  //Make sure the analog-to-digital converter takes its reference voltage from
  // the AREF pin
  analogReference(EXTERNAL);
  pinMode(xpin, INPUT);
  pinMode(ypin, INPUT);
  pinMode(zpin, INPUT);
  pinMode(red, OUTPUT);
  pinMode(green, OUTPUT);
  pinMode(blue, OUTPUT);
  digitalWrite(red, HIGH);
  digitalWrite(green, HIGH);
  digitalWrite(blue, HIGH);
int x = 0;
int y = 0;
int z = 0;
int prex = 0;
int prey = 0;
int prez = 0;
int redVal = 0;
int greenVal = 0;
int blueVal = 0;
boolean redb = false;
boolean greenb = false;
boolean blueb = false;
void loop()
  //Defining previous readings
  prex = x;
  prey = y;
  prez = z;
  Serial.print( analogRead(xpin));
  Serial.print("\t");
  //add a small delay between pin readings.  I read that you should
  //do this but haven't tested the importance
  delay(1);
  Serial.print( analogRead(ypin));
  Serial.print("\t");
  delay(1);
  Serial.print( analogRead(zpin));
  Serial.print("\n");  // delay before next reading:
  //delay(sampleDelay);
  delay(1);
  //Reading current x,y,z
  x = analogRead(xpin);
  delay(1);
  y = analogRead(ypin);
  delay(1);
  z = analogRead(zpin);
  //Detect if the difference between last reading and current
  //reading is too far apart, tap occured
  //Tap detection is quite sensive, too sensitive?
  if(
  (x > (prex + 10) || x < (prex - 10)) ||
  (y > (prey + 10) || y < (prey - 10)) ||
  (z > (prez + 10) || z < (prez - 10))
    Serial.print("TAP!!");
    Serial.println();
  //Switch color
  if(redb){
   redVal = 255;
   greenVal = 0;
   blueVal = 0;
   redb = false;
   greenb = true;
  }else if(greenb){
   redVal = 0;
   greenVal = 255;
   blueVal = 0;
   greenb = false;
   blueb = true;
  }else if(blueb){
   redVal = 0;
   greenVal = 0;
   blueVal = 255;
   blueb = false;
   redb = true;
  }else{
   redVal = 255;
   greenVal = 0;
   blueVal = 0;
   greenb = true;
  delay(1);
  analogWrite(red, redVal);
  analogWrite(green, greenVal);
  analogWrite(blue, blueVal);
  //END of color switch
    delay(150);//Delay to prevent false tap detection
      delay(1);
      delay(1);
  //End of tap detection
  delay(10);
What happens is that when i write the program, the Led starts out lighting up BOTH green and blue. When i TAP it changes to RED. When i tap again, it is still RED. When i tap again, it goes to BOTH green and blue.
I can't see why :S
Halp?
mollekake
Jun 30, 2014
37
Figured it out after a lot of frustration. I did it the opposite of correct.
In order to light up blue, red and green must be at 255 and blue at 0. Green is red and blue 255, and green 0, and so on.
