Assistance in decoding a circuit diagram
yolo
Oct 28, 2019
17
I started following a YouTube tutorial to build an FM radio. After starting to connect, I realized that it's not as easy as I thought.
Until now I've connected a 10k preset with LM386 . But I'm not sure whether I've connected it in the right way and I don't want to proceed with such doubts.
I need a step by step guide for connection.
For example, to connect the 10k preset, connect the pin 4 of IC to left leg, pin 3 of IC to right leg. (Circuit not followed in my example) .
Check the attached file for circuit diagram
And I also would like to know why stuffs are connected in the way they are.
14,285
Pin 3 of the ic connects to the wiper which is commonly the center leg of VR1.
That means you'll haved to study electronics, learn the basics, learn to read and understand datasheets etc. There's no way this can be explained in a few simple statements.
We have a section on book reviews. You'll certainly find good recommendations there to get you started.
yolo
Oct 28, 2019
17
Hello, thanks for your time. Like you said, I'll connect the preset. But as I've asked, I need all other components' connection too. If you can, please have a look at the circuit diagram and guide me on connections.
14,285
Zhe connections are all shown in the schematic diagram.
You may need to look up a datasheet of the two transistors to find which pins are base, emitter and collector respectively.
You'll also have to observe the polarity of capacitor C4. It is shown on the case of the capacitor.
All other 2-pin components can be connected eitehr way.
yolo
Oct 28, 2019
17
This is my first ever circuit build. I don't know how to read circuit diagrams.
14,285
Read here or search for "how to read a circuit diagram" with your favorite search engine. There are quite a few tutorials out there.
14,285
Sorry if I'm being too noob-ey
No need to excuse. WE all have been noobs one time or another.
Imho the important thing is that you accept your missing knowledge and are willing to learn.
You may want to consider starting with electronis kits instead of building things from scratch. Kits come with (more or less clear) instructions and all the right components. You'll have a quicker feeling of success which in turn may boost your motivation to go on.
yolo
Oct 28, 2019
17
Capacitor C4 has a + sign near one end. So the lengthy leg of the capacitor comes that side. But capacitor C3 does not have such signs. So can I assume that it is the positive side that gets connected to IC pin 5 ?
duke37
Jan 9, 2011
5,364
C3 is a 0.1uF (100nF) capacitor and is almost certainly non-polarised so can be connected either way round.
How do you define the positive side?
yolo
Oct 28, 2019
17
You are right. C3 is non-polarized. C4 is a electrolytic capacitor and so it's polarity is mentioned. So I am connecting C3 without any polarity in consideration
yolo
Oct 28, 2019
17
The 22pF variable capacitor has three legs. How do I connect that?
14,285
two of the three are likely short-circuited (measure resistance near 0 Ω with multimeter). Use one of these two and the remaining third for your circuit.
Polarization is irrelevant. However, depending on which one of the two connected pins the direction of tuning when turning the axle of the variable capacitor will change.
Most likely only two of them are connected, the other one is for stability when mounting on a board. It is also a non-polarized capacitor and can be connected either way around.
duke37
Jan 9, 2011
5,364
What meter have you?
A digital meter will have a resistance capability so you can determine whether two pins are connected together. It may also have a capacitance range to determine the active pins.
yolo
Oct 28, 2019
17
I need some assistance in purchase. C3 and c2 of this circuit are 100nf capacitors. But I cannot determine which one to buy. Can someone please check out https://www.electronicscomp.com/ and tell me which one to buy.
14,285
Which one do I follow now @BobK and @Harald Kapp
@BobK the 22 pF capacitor C1 is adjustable so I think I may be right.
These are not critical. you can use any 100 nF capcitor as long as the rated voltage is 16 V or more. From your link e.g. this one, although it is rated at 63 V and therefore oversized.
You probably really should go for a kit.
