Audio Switching?
MAHABA
Apr 13, 2012
14
Hi everybody,,
How could I activate (switch) a relay by an audio signal received from a source like cd-player??
The relay should switch on, when audio (music) turned on.
thank you
14,317
Amplify the signal, rectify it (diode), add a low pass filter to smooth the signal, add a schmitt-trigger circuit and set the threshold of the schmitt-trigger such that it will trigger at the signal level you want. From the output of the schmitt trigger control the relay.
Harald
MAHABA
Apr 13, 2012
14
Hi Harald Kapp,,
You significantly prove that your are a Senior Member..
thanx a lot..
Could someone provide a schematic diagram (with resistor values) of how the circuit will look like?
MAHABA
Apr 13, 2012
14
Hi Harald,,
thanx agin for your help ^_^
I am waiting for ideas from other members,,,
gorgon
Jun 6, 2011
603
You don't tell if the relay should switch OFF when the signal disappear, or stay on?
TOK ;)
Unless you have a problem with the information Harald gave you, or until you give us more information describing why his answer is inappropriate, you are unlikely to get further answers.
MAHABA
Apr 13, 2012
14
What I need is a schematic diagram of what Harald said>>
He said "Amplify the signal, rectify it (diode), add a low pass filter to smooth the signal, add a schmitt-trigger circuit and set the threshold of the schmitt-trigger such that it will trigger at the signal level you want. From the output of the schmitt trigger control the relay."
Also, new idea of simpler circuit is appreciated with circuit diagram..
thanx guys
