auto-sensing voltage switch
4
440roadrunner
I need to find or design a circuit that detects the input line voltage (i
will be either 110vac or 24vac), and then toggle a switch (or relay) t
the output path to the proper circuit.
The logic of the circuit would be something like:
If line-in voltage is 110v then switch position A
If line-in voltage is 24v then switch position B
Unit should handle 2amp max current draw.
Is anything like this commercially available?
If not, any ideas?
I know this is probably something quite simple for you guys...
Thanks!
ehsjr
440roadrunner said:
I need to find or design a circuit that detects the input line voltage (it
will be either 110vac or 24vac), and then toggle a switch (or relay) to
If not, any ideas?
Thanks!
It's a 120 VAC relay. When 24 VAC is applied to its coil,
nothing happens, and the relay stays de-energized. When
120 VAC is applied to its coil, the relay is energized,
and the contacts transfer.
+------Normally Open
| +------ Common
o o o------ Normally Closed
Vin ------|Relay| | | |
------|Coil | |> |<-+
Shown de-energized. A path for current exists from Common
to Normally Closed. When energized, that path is opened,
and a new path is created from Common to Normally Open.
You can see such a relay at
http://www.allelectronics.com/
Put RLY-453 in the search box. That particular relay
has two sets of contacts, and the contacts can handle
12 amps.
Ed
Rich Grise
| +------ Common
12 amps.
I saw a guy do this to switch from 120V to 240V mains, but
he added a diode and a cap for some reason, and every time
I plugged one in to 240 to test, I kinda cringed expecting
an explosion. It did seem to work OK, however. :)
Cheers!
Rich
Pooh Bear
If not, any ideas?
SGS-Thomson once made an IC specifically to do this ( except it was 120/240V
). One important thing to note is that the status needs to be latched once
detected or you may get a loud band under brown-out recovery conditions !
http://www.datasheetcatalog.com/datasheets_pdf/A/V/S/0/AVS08CB.shtml
Graham
Jasen Betts
like Deep Purple -
Smoke Upon the Water
(sorry)
Bye.
Jasen
