Battery charger/battery type NMH
pepi
Sep 20, 2017
35
Need some advice regarding a charger. The suggested charge rate 12dc 200mA ,
The question any AC/DC power supply with an output of 12dc 200mA is usable ?
Beers on me
Pep
Beers on me
Pep
Plenty of simple circuits out there on the web for charging NimH using a basic LM317 regulator as a constant current device.
You will require a power supply with an output voltage greater than the battery you are trying to charge though.
Then again there are ways around this by using a small $2.00 boost converter with your power unit.
14,317
The simple constant current battery chargers imho all suffer from an inadequate means of terminating the charge cycle: time. If you leave the batteries in the charger for too long, they will be overcharged and their lifetime will be decreased.
A goof charger detects end of charge e.g. by the dv/dt method and/or by registering the temperature rise of the battery near end of charge. You can find many dedicated NiMh charger ICs (often doubling for obsolete NiCd, too).
Or you build one of the simple circuits and life with the drawback of having to time the charge.
A rather standard question with a rather standard answer. The output rating of any typical power supply means:
- voltage is output as stated, in this case 12 V.
- current output is defined by the load, with a maximum current draw allowed as stated, in this case 200 mA.
By no means does this imply that the output current will be 200 mA for any load nor does it imply that the output current is safely limited to 200 mA. You may be able to draw more than 200 mA but this will overload the power supply and in the long term lead to premature failure of the power supply due to overheating.
My favorite comparison is a mains outlet in your home. You'll get 115 V regardless of the load. A small desk lamp will draw only a few Milliamperes whereas an appliance may draw a few Ampere - all from the same outlet. Current is limited only by the fuse in your distribution panel.
pepi
Sep 20, 2017
35
I've realized I forgot all the specs in order to define the question. Let me clean it up and clarify, and say sorry for the confusion
Assuming I am after a wall charger, found on every portable phone. Need to be looking for one with the output of 12vdc; 200mA
5 watt transmitter
Transmitter label: 8.4Volts battery power pack
Charger 12vdc; 200mA
Battery pack label: 8.4Volts:1300 mA
Typing this, I answered my own question LMAO, one of the great things about a
forum.
Nevermind
Pep
WHONOES
May 20, 2017
1,242
You can use a simple current limited charger without wrecking your batteries.
You charge the batteries at the 14 hour rate. For this, you set the charge current to 1/10th of the batteries capacity. This is so because the process is only 60% efficient.
Using this regime you can leave them on charge almost indefinitely.
I've been doing it for many years with my R/C equipment with no premature failures.
