old century battery charger transformer leads came off
63split
May 31, 2024
5
I HAVE A CENTURY BATTERY CHARGER THAT IS THE BEST CHARGER I HAVE EVER HAD IT IS NUMBER E143111 MODEL 141-272-000 IT HAS A DATE CODE 022894 THE LEADS CAME UNDONE AFTER I THE TRANSFORMER MOUNTING BLOTS CAME UNDONE I CALL CENTURY AND THEY DON'T HAVE A SCHEMATIC FOR THIS MODEL AND HELP WOULD BE APPRECIATED
Delta Prime
Jul 29, 2020
2,996
You are going to have to speak up I can't hear you.
You going to have to give me a second I got this ringing in my ear see if I can't find a schematic for you... Or did you want a sandwich?
63split
May 31, 2024
5
thank you for the reply but my problem is the terminals on my transformer run parallel to the mount not from the center out if there was a way to ohm test each terminal to know what lead goes on that would help
Delta Prime
Jul 29, 2020
2,996
Call century again obviously they lied if that information is on the internet readily available speak to someone who knows what the hell they're talking about.
Work your way backwards from the schematic obviously the terminal block is not there in this schematic I gave you the website so you can meander around. I just punched in 141-272. Show some initiative like punching the date code and their other number starting with "E". Does the insulation on the conductors the color in the schematic match those coming out of your transformer? If so work your way back from there.... Look at what is connected to that terminal block you can do that as well Mark it down. it is the process of elimination.. If you're in Southern California I'd do it for you.you says the best charger you ever had .Now its your turn to show it some love. You didn't maintain it that's why stuff falls off. That's all I got and unfortunately I don't think it's good enough. Sorry about that... By the way you got any garlic bread to go with all that spaghetti!
Looking at the supplied circuit diagram, it's quite a complex arrangement.
Normally one would expect to see differing outputs dependant on the secondary taps however this "appears" to have some primary input control.
Clearly the four wires in photo 1780 would go to 4 of the 5 terminals on the transformer but which and in which order?
One could possibly identify which 4 terminals were used to begin with as one would be a lot dirtier than the other 4 and possibly one could verify the four used by the marks left by the spade terminals.
Then I see one of the white conductors apparently disconnected as well but assume that one to have been disconnected from the switch.
Lay of the wiring in it's "normal" state usually tells a lot.
Order of the connections is important and without a "full" circuit diagram, i.e. that of the transformer windings, one could not be certain.
Perhaps knowing the switching sequence might be of assistance but then again still no transformer diagram.
Maybe show a photo of the charger and display on facebook or similar with an appeal for an "internal workings shot" might help.
63split
May 31, 2024
5
well i did call a few times to century the first person said they never put that transformer in their chargers I love when someone tells you that and you have one right in front of you the second time I called he sent me the schematic that didn't match at all today I that actually told me what terminal the neutral went on and from there it was easy to figure the rest out with my volt /ohm meter and its ALIVE thank you for all your help with this
63split
May 31, 2024
5
thank you for the input I got it working today
Would be good manners to include it here for the sake of others who may come along with same/similar........
63split
May 31, 2024
5
the wiring on my century battery charger transformer that works for my battery charger not sure it would work for others because it doesn't match the schematic century has
Thanks....I was also referring to the schematic which century sent you............
