My brother has given me a very unenthusiastic battery charger to look at. I have evicted the spiders and brushed out the chaff.
There is no name or model, it is labelled 6 Amp and has a 6V/12V switch. It does not have an ammeter but has 6 leds.
The main charging circuit has a bridge rectifier, two 5Wr1J fat resistors in parallel. a gismo and a 10A fuse.
The auxilliary circiut contans an LM358 dual op-amp, several S9014 npn transistors and the leds.
Action!
With a bulb as 1.5A load the first led lights and the bulb lights up for about 15 seconds, then the current gradually drops and rests at about 250mA. The only current control is the gismo which gets HOT.
Gismo
I assume this is a thermistor. It is about 19mm square and about 2mm thick. labelled
L30
700
150T
I do not find this when googling. I would like to try a replacement.
Help appreciated.
Action!
Gismo
L30
700
150T
Help appreciated.
