Battery Charger rewire help
Fleethirte
Aug 23, 2022
So I have a battery charger that has quit working.
I am pretty sure it’s the control / charge board.
Transformer seems fine!
My question is, why do I need to bypass the control board and basically just use the transformer manually.
Battery charger is 2,40 and 200 amp unit.
My initial thinking is to put a bridge rectifier on the dc output of the transformer and it should be gtg…. However I am sure it’s not that simple…..
Minder
Apr 24, 2015
3,561
Not quite that simple, most decent chargers use a controlled-charge circuit that senses when the attached battery is up to charge and regulates the charge accordingly by lowering the current output.
Kiwi
Jan 28, 2013
506
"200 amp", that is a serious battery charger.
ivak245
Jun 11, 2021
144
The output of the transformer is AC- then it becomes DC after being rectified. Not really sure what you are trying to do here. And 200 Amps? That transformer would be as big as a washing machine!
Minder
Apr 24, 2015
3,561
The OP appears to intend bypassing the defective regulation circuit and going directly off the rectified DC ! ?
Not a good idea.
Externet
Aug 24, 2009
943
IF the regulation control circuit has a problem.
Modern battery chargers have circuitry to recognize the battery to be charged is good and not a defunct thing extracted out of the backyard weeds. Can easily mislead users.
Before performing any surgery, try it with a known healthy battery connected to it. After that we can suggest something.
Remember a lead acid battery that has kept discharged over 24 hours will never recover full capability.
---> Have you ever read its manual ?
kellys_eye
Jun 25, 2010
6,512
If it really is a 200A charger then the controller is absolutely necessary to save the wiring, the battery and the user from potentially dangerous overloads. Bypassing it is not a good thing to attempt and we wouldn't condone such actions anyway.
If it's a typo and only 20A, well, that's still an issue and a good current capable of starting fires......
Give us the make/model number and post pics of the unit and the control board....
