audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Hi Wald,
Your calculations are correct but you have the same problems as before:
1) The dictated collector current requires odd resistor values. Select the RC and RE resistors first. A standard 2k for RC and 100 ohms for RE will result in a gain of 20 and a collector current near 2mA.
2) The collector current of 10mA is rather high which will quickly drain a little 9V battery and cause a low input impedance.
3) The lack of adding a bypassed emitter resistor to raise the emitter and base voltages means that the DC operating point will change too much with different transistors.
You calculated using a Vbe of 0.65V. The datasheet shows a typical Vbe of 0.72V at a 10mA collector current and it could be from 0.65V to 0.85V.
Calculate again using your resistors and a Vbe of 0.85V, and you will see that your transistor's collector voltage will be very high and the transistor is nearly cutoff! :'(
Design the circuit again with RC= 2K, RE= 100 ohms and a bypassed additional RE= 560 ohms to raise the emitter and base voltages about 1V. Then it will have a voltage gain of 20, a fairly low current, a fairly high input impedance and work well with any 2N3904 transistor with a current gain from 100 to 400 and a Vbe from 0.55V to 0.75V (at a collector current of nearly 2mA). ;D
