riccardo manfrin
- Jan 1, 1970
- 0
With reference to this network (of common emitter amplifier)
http://4.bp.blogspot.com/_Dw6bXh3FG1Q/R61fbJKINdI/AAAAAAAAAOc/Ae6ExBcFSdI/s320/CE.GIF
I'm trying to bias the BJT through the two tunable parameters
- base resistance R_b
- collector resistance R_c
R_c should be chosen
- small enough to admit the amplification of the whole input signal dynamic (without entering saturation nor cutoff), but
- high enough to support a good current (I_c) to voltage (V_ce) gain and
- small enough to avoid a high output impedance.
Once R_c has been defined to match above criteria, R_b is used to move the Q-point in the middle of the amplifier range by imposing the I_b and consequently the voltage drop on R_c, due to the collector current I_c.
Nevertheless, for a real transistor (I'm using a simple BC237B), the value of h_FE has a very high variance (fairchild datasheet reports a min max value of 120 and 800 respectively, without even providing a typical value).
I would like to know what is the correct procedure to follow in order to find appropriate value of R_b so that the at regime quiescent V_ce = V_cc/2 (so that half of the dynamic is dedicated to positive swinging and the over half to negative).
Regards,
RM
Regards,
RM
