Blown Canon LC-E6 charger for LP-E6 batteries
DaFlea
Dec 29, 2016
4
Hello, few month ago, i put my charger on power outlet, and it suddenly blown up, with white smoke and smell like something is burning inside. With just curiosity and no knowlege about electricity, i opened my battery charger, and found out that a resistor is burned in pieces (ring color is unreadable). It printed on the board that it's R1 (resistor number 1?).
So i get a solder, and take out that piece from the board. Unfortunately, now i lost that pieces.
Now, i need to identify, what kind resistor is that, so i can order that spare part somewhere, maybe someone here can help?
Here i attach some picture
Thank you, sorry for my broken english.
14,487
hi ya
welcome :)
can you please do some larger pics and orientate them longways instead of vertically
up to a max of 1000 pixels on the long side
your pix are a little too small to make out the details
that resistor probably failed because something else beyond it failed ....
maybe the switching transistor in the top left corner of pic 1
Alec_t
Jul 7, 2015
3,821
The board around R1 doesn't look scorched, so it was presumably a short-duration overload which fried R1. I agree with Dave that the likely culprit is the switching transistor. It would also be worth checking what looks like a bridge rectifier, BD1, just above the circuit tracks with the saw-tooth edges in the first pic.
DaFlea
Dec 29, 2016
4
Hello guys, thanks for your reply. Really appreciate that.
Ahhh... After reading your comment, I do some deep search, and I found something else is blowing and burned surrounded area. I didn't know that earlier because its normally covered by transformator and a large heatsink.
Is that a capacitor? And what type is that?
I don't know, but it seems like some coating of something for me. Flux, maybe..
Oh, and I'm wondering is this thing (that have large heatsink on it) is affected by that explosion? I got multimeter but don't know how to use setting. (silly me)IMG_0638.JPG
Rayregula
Dec 20, 2016
84
If something is wrong with it would not be because your capacitor blew. But there was an over voltage that caused the capacitor to blow, the over voltage might have harmed it or it may have gone bad and caused the over voltage.
Rayregula
Dec 20, 2016
84
Yes that is a capacitor. If by what type you mean voltage and capacitance the other side should have what your looking for. :)
73's de Edd
Aug 21, 2015
3,730
Sir DaFlea . . . . . . .
Your missing component is a 10 ohm - 2W 5% metal film . . . initial charge bufferring . . .resistor.
Might as
well leave it out until the unit has been completely checked out.
Since that would be a good point to insert a series 60 watt incandescent series lamp for permitting
an initial non destructive / shakedown power up . . . . AFTER weeding out any and all possibly bad parts being within in this raw DC power supply / SMPS section.
Initially check that the RED rectangle marked up line fuse has blown or not, then go down and check out the
4 diode sections within the BR01 BLUE rectangle marked up full wave bridge rectifier, seeing that it does not have any shorted diodes within it.
Check across the LARGE black electrolytic just behind it for any short across it.
Move down to the second RED rectangle marked MIP2G4MO switch mode IC mounted onto the heat sink at the very end of the PCB and check out all of its 7 lead interconnect possibilities for any shorts.
Pins 4 and 7 go to the internal POWER FET inside of the unit and would be the most suspect to have developed a short.
The GREEN rectangle marked electroltyic that blew its seal at the bottom and leaked electrolte, was probably the initial . . . number 1 item to go . . . . and then other semis failed after that. Your mystical, and odiferous white smoke should have originated from that electrolytic also.
And then a final . . . psssssssssssssst . . . coming from that RED chemical fuse . . . as it opened up.
This board will need those parts pulled and that area, and then, very SERIOUSLY cleaned up of all electrolytic surface residue.
PHOTO REFERENCES:
73's de Edd
DaFlea
Dec 29, 2016
4
Man, I tought its gonna be as easy as soldering new resistor in place. Realized that theres lot of things happened here.
Just realized that it was a fuse! My first tought when opening this charger is, wheres that fukin fuse. And, yes, it got blown up too. I can just replace it with glass fuse with same specification, right? Because I think that woud be easier to get.
I've checked it with my multimeter. All of It's 4 lead is connected. Is it normal? I don't really know how to check it, tho.
Its clean, I think nothing suspicious here :)
Pins 2 and 5 go to the internal POWER FET inside of the unit and would be the most suspect to have
developed a short.
Actually, mine only got 6 lead, and it seem in good condition, but definitely gonna replace this IC, just in case.
Anyway, thanks for answer mate! Awesome!
14,487
really ?
looking at it, it's in dreadful condition and there seems to be possibly missing or burnt circuit tracks around it
those big and small caps need to come out beside that IC and also the IC. The board needs to be cleaned up to see how much damage it has suffered
Then another assessment of if the unit can be repaired or not
73's de Edd
Aug 21, 2015
3,730
Here is an " in Englee " typical application note from Puny Sonic, on their series of SMPS power IC.
Note that it is configured to output a MUCH greater power level than is being needed and generated in your unit.
Your input line fuse is using but a mere 1 amp fuse .
Your ruptured electrolytic photo, did not expose its specifications marked side, but on this unit, the probable equivalent would be the CVCC marked unit, which is on the " HOT " AC line . . . left side of the power supply.
Should you have a breakdown of the semis within the MIP2Gxxx, that could direct a fierce voltage level through this cap directly to ground.
The large upper CIN main filter lives a long untaxed life, with it merely operating at the 50/60 cycle line input voltage and frequency level.
Any electrolytics used down in the MIP2Gxx support area have a strained life due to their having to operate at FAST switching speeds of 10s of thousands on up to 100s of thousands of cycles of operating frequencies.
They take one hell of a hammering from those full voltage transitions and are prone to failure after some years of use.
That is also being particularly true over on the " COLD " side of the circuitry on the right half winding of the central Switch Mode Transformer where you can see involved Cout and Cfil units.
" Typical " Circuit . . . . . as Excerpted from a PunySonic Application Note :
VISUAL TUTORIAL
( On the testing of the 4 diode sections, internal of the units Full Wave Bridge Rectifier unit.)
The particular casing outline on the unit used in your system, is exhibiting a variant, in the respect
of the A.C. voltage coming up the board is connecting into side by side terminals on the bridge.
The rectified D.C. output voltage then shows up as side by side +and - terminals, just above.
With proper polarity foil connections routing over to the large black Cin main supply reservoir capacitor.
73's de Edd
