Blown component on board from TV. Can you Help?
Grimmjow
Oct 30, 2016
Hi There,
I had a problem with my TV, it was just clicking and not turning on. I opened it up to see if any of the capacitors had blown up (common problem i'm told) All of the capacitors seemed fine however, one of the components had failed it looks like this
And it is marked with the code C5092.
Am i able to replace this component and it will work or would something else have caused it to fail?
Any insight you could offer would be great. Thanks.
grumps
Jul 11, 2015
12
voltage rating of that capacitor's replacement should exceed highest voltage on other components ;
unlucky transistor ( behind it ) may have caused - or suffered from - whatever happened to c5092
so a diode tester will confirm if said xsistor is shorted , or leaky ;
14,485
HI
welcome to EP :)
there is a possibility that something else failed that caused this capacitor to fail
a schematic or service manual is what you need to find out the value, capacitance and voltage rating, of said device
see how you go searching on google :) and then share a link to where it is
grumps
Jul 11, 2015
12
what type of tv is this ? ( date of manufacture , might help );
