breaking the speed of light article on howstuffworks.com
John Woodgate
I read in sci.electronics.design that John Larkin <jjSNIPlarkin@highTHIS
landPLEASEtechnology.XXX> wrote (in <isaa011n7plsije0ucj8ek3hdjirteuvak@
4ax.com>) about 'breaking the speed of light article on
howstuffworks.com', on Sat, 5 Feb 2005:
The working position is "well,
so far, this theory looks really good, so we'll work with it until
somebody proves something better." It's sort of an attitude about life,
I guess.
It's also excellent science. We still use Newtonian mechanics to design
cars, planes and ships, even though we know it's not quite right. But it
doesn't work for TV cathode-ray tubes.
John Larkin
"If you aim right, most of the angular momentum of the asteroid gets
transferred..."
And if you don't aim right, we all die.
Well, that's not a very cheerful attitude. Just keep the engineering
units right.
John
John Woodgate
I read in sci.electronics.design that ~~SciGirl~~ <[email protected]>
wrote (in <[email protected]>) about
'breaking the speed of light article on howstuffworks.com', on Sat, 5
Feb 2005:
"I think John Larkin said it best: "If there's something going faster
than c, it's not a photon." And, according to the definition of
"photon", that's absolutely true."
All right, so I'll rephrase that. No PHOTONS were going faster than c,
but we haven't proven that tracheyons aren't (I've seen that spelled so
many different ways, so I don't know if I'm spelling it right.) Is that
basically saying that, if a photon was to move >c, it would have to be
called a tracheyon?
It's 'tachyon' - 'fast particle'. 'Tracheyon' would be 'windpipe
particle' (cough, cough!).
No, a photon has certain properties, including zero mass and travelling
at C in a vacuum. Tachyons (if they exist) have different properties,
apart from always travelling faster than C. For instance, they may have
imaginary (in the mathematical sense) mass, not zero mass.
~~SciGirl~~
If I cant escape the calculus, I'll have to learn the calculus. Darn.
I've been given the name of a good calculus book by someone earlier,
but I need somewhere to learn precal first. I'm up to the challenge but
I'll probably try it over the summer. I won't have time now, and I
really doubt I'll understand much of it. I learned almost everything I
know about physics between September and now, but math doesn't come
that easily.
~~SciGirl~~
Well it's true! If someone makes the slightest calculation error we'd
all be dead. I wouldn't trust someone to change the Earth's orbit with
an asteroid. I'm usually pretty optimistic, but that seems... too
risky.
Luckily, I won't be around then so I won't have to worry about it. I
like the time period in which I live.
~~SciGirl~~
Maybe I just think that because I make so many calculation errors, lol.
~~SciGirl~~
lol! windpipe particle... I should have known that, it comes from
trachea.
Traveling has one L, not 2. That I'm pretty sure of.
John Larkin
What sort of voltage does it take to get electrons to relativistic
speeds? I used to know that. Maybe the voltage that, ignoring
relativity, would boost an electron to C. Something roughly 100 KV, I
recall.
John
John Larkin
recall.
John
256 KV; see abse.
John
Joel Kolstad
~~SciGirl~~ said:
Its hard to imagine where what we can rely on begins and where it ends.
For instance, the emission of a photon violates the law of conservation
of energy. The law is of good purpose to, say, my science class, but
you can't really depend on it in qed.
At some point you should receive the lecture about how, in beginning
classes, there are plenty of simplifications and outright mis-truths told in
order to make understanding easier. The supposed "law" of conversatoin of
energy only applies under certain specific scenarios and -- while those
scenarios are quite common in everyday life -- once you start playing with
quantum mechanics you've violated the assumptions upon which the "laws" were
founded.
Quantum physics is full of many non-intuitive and seemingly contradictory
results. :)
Joel Kolstad
~~SciGirl~~ said:
And where do we get the enormous amounts of energy and equipment
required to do that?
Army core of engineers? :)
They do a fine job literally leveling mountaintops when they build earthen
dams, moving the Earth seems like it might still be within their charter...
John Fields
transferred..."
Joel Kolstad
Brian said:
Conclusion: to travel beyond the speed of light, one must be able to
either:
a) warp space
b) stop time
Only if you're a photon. :)
~~SciGirl~~
"At some point you should receive the lecture about how, in beginning
told in
of
with
were founded."
"the ideal gas" comes to mind.
~~SciGirl~~
a photon is defined as massless, but can you say it has volume?
~~SciGirl~~
i suppose it doesn't literally take up space, but it has a size right?
John Fields
called a tracheyon?
Gareth
trachea.
Depends where you come from.
Gareth.
K
Ken Smith
Was the other signal called the "latch", by chance?
Actually no.
IIRC it was called gate.
"trigger" controlled the current in a coil and "gate" controled the
sampling of the ADC circuits. Both were mis-named for what they really
did.
