breaking the speed of light article on howstuffworks.com
K
Ken Smith
I don't think this version of the experiment can be actually done. The
"measure the arrival times" part is not easy unless the shutter and the
detector are closer together than the length of the trip. If they aren't
there will be trouble making the shutter and the timer be in sync.
Why trouble? Put the trigger device midway between the shutter and the
detector and run coax (or any other signal medium) to both. By
symmetry, they are triggered simultaneously regardless of separation.
There are lots of simple ways to do this.[/QUOTE]
You are trying to send really fast edges a fair distance. The VP of coax
is not a constant. It varies by several precent from the start of the
roll to the end. If the FLT is only 1% faster that C this could be a
confounding factor.
You'd be better off with light beams as they go at the same speed. You
would want to use one beam and a beam splitter to make the transmit timing
exact. The optical receivers would have to be matched quite well too
unless the distances are many feet.
Jim Thompson
"At some point you should receive the lecture about how, in beginning
classes, there are plenty of simplifications and outright mis-truths
told in
order to make understanding easier. The supposed "law" of conversatoin
of
energy only applies under certain specific scenarios and -- while those
scenarios are quite common in everyday life -- once you start playing
with
quantum mechanics you've violated the assumptions upon which the "laws"
were founded."
"the ideal gas" comes to mind.
I think you're really 41 ;-)
...Jim Thompson
Pooh Bear
John said:
Same sort of thing, altering the shape of a pulse and thinking that
makes it go faster. Optically, an oscillatory burst can appear to
exceed C if you sort of stand back and squint, but no photons are
going faster than C.
I recall Tektronix illustrating that the a scope trace on one of their GHz
scopes resulted in the display apparenly travelling faster than light.
Of course nothing *actually* had to travel faster than light to cause the
effect.
Graham
~~SciGirl~~
"I think you're really 41"
If I was 41, I'd understand calculus, wouldn't I?
Pooh Bear
E=MC^2-GammaMV is the full equation. Gamma is proportional to how fast
you are going. It effects length contraction, time dilation, and
apparent mass. Basically, by looking at the equations, as you get
closer and closer to the speed of light, you're apparent mass gets
larger and larger with your mass equalling infinity at the speed of
light. Hence it would take an infinite amount of energy for you to get
to the speed of light. Photons get around this by being massless.
Hmmmm... but photons have energy. How so if no mass ?
Isn't the wave / particle debate fun ?
Graham
~~SciGirl~~
Well, if matter had to have mass to have energy, then what would energy
really be? A photon is not matter, it's pure energy.
I have always wondered, though, what the link is between light as a
particle and light as a wave.
~~SciGirl~~
For that matter, all waves can be described as particles
~~SciGirl~~
~~SciGirl~~
It is actually incorrect that we refer to photons as particles, as the
definition of particle in qed is "A subatomic object with a definite
mass and charge."
That's easy, they just don't have kinetic energy. Kinetic energy is
1/2mv^2 which, coupled with mass inflation, is why you would need
infinite energy to reach the speed of light. But it is not the only
energy in the ballgame.
Jim Thompson
I think you do. You are wise in ways that take "mellowing time" ;-)
...Jim Thompson
K
keith
Actually no.
IIRC it was called gate.
"trigger" controlled the current in a coil and "gate" controled the
sampling of the ADC circuits. Both were mis-named for what they really
did.
Ah, I wuz just wondering if you fell into the "wonders" of LSSD design.
I've heard this story that might make you feel better. Einstein was
once told that he was probably one of three people in the world who
understood his Theory of Special Relativity. His reply, "Really, who's
the third?"
K
keith
Add this to your thinking....
Light shows particulate characteristecs, this shows they MUST have a maximum
speed.
Oh no! Enter Kevin to straigghten alll this out, again....
Light being pure energy "w/o" mass, it has to be the fastest.
Conclusion: to travel beyond the speed of light, one must be able to either:
a) warp space
It's already warped.
b) stop time
Reverse time.
~~SciGirl~~
No, I am really 14. I'm serious. On my birth certificate, I was born
December 4th 1990. I'm no genius either, I just have an enormously huge
obsession with science.
~~SciGirl~~
"> Light being pure energy "w/o" mass, it has to be the fastest.
a) warp space
b) stop time
Reverse time."
That's basically what I said earlier
~~SciGirl~~
I've made 4 science quizzes on allthetests.com: the SCIENCE quiz I, the
SCIENCE quiz II, the SCIENCE quiz III, and the SCIENCE quiz IV. The
first three have some issues that can be argued. The last one is the
Extreme Physics one, and can be found at this url...
http://www.allthetests.com/quiz12/quizpu.php?testid=1107651093
If anyone has time, I do need some critique, I doubt it's entirely
correct, but I sure hope it's better than that other guy's. Remember
that it's all IN THEORY, and maybe all the times it says "is" it should
say "might be".
~~SciGirl~~
Also, what exactly would be the point in saying I'm 14 if I was 41?
That wouldn't benefit me in any way.
