Buck converter controlled by a microcontroller
salahaldeen
Nov 26, 2006
13
Here is a graduation project to have 10 volt input into a buck converter (step down), where the output is connected to the microcontroller through ADC as a feedback, so any variations of output (load change or whatever) than stated by the reference set by the user the microcontroller should adjust it and display output signal and status on a graphic LCD.
Anyway, I hope you can suggest a good buck converter design where the microcontroller can control the output through the pulse generated for switching of the converter.
Many Thanks
ante1
Jan 24, 2004
4,136
Why would you reinvent the wheel? There are a lot of chips out there with everything built in. All in one chip converters with high stability and no fuzz, why make something more expensive, complicated and less reliable?  :-\
