Calculating current through resistors
Diar
Jul 27, 2014
12
Ok so I'm pretty new to electronics. Taking a part time course one day a week and trying to fit it in with working 60 hours a week. My lecturer moves through things pretty quickly and the rest of the class have a background so I'd rather not hold them back with my pretty basic questions seeing as its a higher level course (don't ask how i managed to blag my way onto it).
So I'm stuck trying to calculate the current through I1 and I5 in this circuit, I've worked out the total resistance for the circuit and the total current, I just cant figure out how to calculate current through these points, its just not clicking for me.
Gryd3
Jun 25, 2014
4,098
Remember that the current through components in series will be the same.
Voltage across components in parallel will be the same.
We can make the observation that your complicated resistor network can be looked at as 3 resistors in series. You have the first resistor where I1 is located, then you have your small network of parallel resistors which can be looked at as a single aggregate resistor, then you have the last resistor. I5 is the current flowing into the last resistor. Now because these points are in series, we can say that I1 and I5 will be the same. We can also determine the current flow through the circuit because you have calculated the total resistance of the circuit yes?
Once you know the total resistance, you can calculate the total current through your circuit. Like I stated above, all current will be the same through a series portion of the circuit. Once you connect the dots, you'll have your answer.
chopnhack
Apr 28, 2014
1,576
Agreed, the group in the center is nothing more than nested parallel resistors that can get resolved down to an equivalent resistance. Can anyone show the math to distribute the voltage drop to each individual resistor in the parallel network?
Diar
Jul 27, 2014
12
When you are calculating out your resistances are you taking into consideration they are k ohm? So it would be 1.6k and 3k ohm. Giving a final current of 0.001A and not 1A as you have stated?
14,306
From your original schematic it is hard to recognize that the values are in kΩ.
Be that as it may: yes, scaling up all resistors from Ω to kΩ will schale down the currrent accordingly from A to mA.
Diar
Jul 27, 2014
12
My handwriting is pretty awful to be fair!
Whilst the equation for parallel resistors R = (R1 * R2) / (R1 + R2) is kinda simple and easy to remember, I find 1/R = 1/R1 + 1/R2 easier to actually apply, and it is far better illustrative of the sometimes useful concept of dealing with conductance rather than resistance.
chopnhack
Apr 28, 2014
1,576
Can you elaborate further Steve?
Conductance = 1 / resistance
If we look at resistors in series, the total resistance is the sum of each individual resistance.
If we look at resistors in parallel, the total conductance is the sum of the conductances for each resistor.
The equation using the product divided by the sum produces the same result as the reciprocal of the sum of the reciprocals. The former method is also easier with slide rules, tables of logarithms, and maybe even for pencil and paper.
However the latter method reinforces the resistance/conductance aspect, is easier to rearrange to find another resistor in parallel to give a desired total resistance, and can be easier to do in your head (well it is for me).
If you find yourself with an equation using lots of resistances in the denominator, it can be a useful simplification to convert these to conductances.
The other thing is that its hard to get wrong. The product over sum can be easily misremembered as sum over product, yielding an incorrect result.
