Calculating the current in a network of impedance elements
Chickwolf
Jan 3, 2014
36
Greeting all, working through the revision notes and am being stumped by a question I was hoping someone may be able to help me with. The question and all the workings for it are attached, but I cant seem to understand what the sums labelled two and three actually are. I get that sum 1 is showing the expression for the voltage, but for the life of me I cant understand 2 and 3. Its probably something silly but was hoping someone could help. Cheers!
dorke
Jun 20, 2015
2,342
That is easy actually:
You have 3 KVL loop equations : (1)-green, (2)-blue,(3)-purple
In each loop equation .
the left-hand side is the value of the "voltage source" in the loop
and the right-hand side is the sum of the voltages on each component expressed in the form of
Vzi=Zi * Izi
(voltage on element Zi) =(impedance of element Zi) * (current through the element Zi)
The current through an element is the sum of the currents (i1 ,i2,i3) through it (with direction taken into account).
Chickwolf
Jan 3, 2014
36
Fantastic thank you! Really cleared that up for me, knew it would be something simple I just wasn't picking up on. Cheers!
