Camping Music Box - PROJECT
stuee
May 7, 2004
183
Hi, i regularly gofishing/campoing with aload of mates and always someone gets a flat car battery from music on. So my idea is.......
A Box with a small sub and midrange speakers, a amp and mabey a mp3/radio player inside..
Now for all this i would like a smallish battery mabey 6-9v rechargeable and i want to put a solar panel on the box lid so it keeps charging it, (in aussie we have lots of sun) Its not a high powered system just a system for some background music.
So any i help / ideas?
I havce speakers already, i just need some 6-9v amp schematic (Mono no more than 100w or less is great prob around the 50w mark) that i can just plug the earphone socket of the mp3 player into the box and ,turn on and off we go.
Also the solar panel, ive not had much dealing with them so any advice for what i would need. size, Wattage or voltage.
Thanks all in advance
Stu
audioguru2
Apr 6, 2004
12,022
Hi Stuee,
Doing some number crunching with your 6V rechargable battery and 100W requirements, if the amp is 60% efficient then it will use 167W and pull about 28A from the battery. The battery charge might last only a few seconds.
Your amp will need a DC to DC stepup converter (like a high-power car amp) to produce 100W into an 8 ohm speaker. With only a 6V supply, a bootstrapped single-ended amp will produce about 5Vp-p which is 0.4W into an 8 ohm speaker at clipping. An ordinary LM386 amp will produce 0.25W. If you use a bootstrapped bridged amp it will produce about 1.3W.
100W into an 8 ohm speaker is 80Vp-p and a single-ended amp will need at least an 86V power supply. A bridged amp will need a 46V supply. The DC to DC stepup converter will have some loss so a 6V battery will have 35A discharge when the amp is producing 100W into an 8 ohm speaker. Of course the battery must be rated for about 70A/hours to be able to play loud music for 4 hours each evening and consist of about 140 rechargable Ni-MH AA cells.
Solar cells? The expensive ones made for trickle charging a car battery are rated at only 15W. Maybe you could cut it in half to charge your 6V battery. After a day in the sunshine it will provide enough battery charge to play full-power music for a couple of hours. ;D
stuee
May 7, 2004
183
like i said its only for background music or radio, mabey 100w is a bit loud the same as 50w. mabey a 30w or less system. What do you think and do you know of anmy schematics so i can make a coupkle and try them.
ante1
Jan 24, 2004
4,136
Hi stu,
You can buy two small 12V 17Ah sealed lead acids and wire them in series, that will keep the losses low since you can use 24V without and DC-DC converter. Or, you can buy a boat battery with a handle 12V 75Ah and use conventional car stereo parts in your box. Solar panels are still expensive about US$ 4 /W, I guess you are not going to spend US$ 800 on this project! ;D
audioguru2
Apr 6, 2004
12,022
Hi Stuee,
You can use an amplifier designed for a car radio and power it from a motorcycle battery:
The TDA1552 is a simple circuit that will provide 12W per stereo channel at clipping into 4 ohm speakers.
The TDA1564 is very efficient since it switches fom single-ended at low power to bridged at high power and will provide 16W for each stereo channel.
http://www.semiconductors.philips.com/acrobat/datasheets/TDA1564_4.pdf
The TDA1562 has a built-in voltage doubler that is used only on demand of high power. It provides about 40W to a single 4 ohm speaker at clipping.
http://www.semiconductors.philips.com/acrobat/datasheets/TDA1562Q_ST_SD_2.pdf
Don't believe the amplifier manufacturers' claims for output power. They use a 14.4V supply and the amps are heavily over-driven to produce 10% distorted square-waves. ;D
Alun
How about using a class D amplifier at least for the bass element of the amplifier?
audioguru2
Apr 6, 2004
12,022
Good idea, Alun. ;D
TI have a nice "240W" class-D amplifier IC. It would provide about 35W into a 4 ohm speaker at clipping with a 24V battery and is so efficient that it doesn't need a heatsink.
It has 36 pins and is a tiny surface-mounted thingy so it would be difficult for Stuee to solder. I think even its bottom must be soldered to the pcb's ground-plane somehow for its heatsink. ???
tas5152.pdf
  • tas5152.pdf
audioguru2
Apr 6, 2004
12,022
Yeah, the LM4651 and its controller mate are easy to make. National was going to cancel them this year but extended the cancellation until next year.
ante1
Jan 24, 2004
4,136
For better economy this might be an alternative for the beach party: http://www.greeleynet.com/~cmorrison/WindMachine.html  ;D
stuee
May 7, 2004
183
So can someone please look at these projects and tell me if any of these are suitable for me and the time they would last for, i dont want it for blasting music out, jsut as background music for a quite fishing spot we always goto....also i only want it in MONO not stereo so would that make these last alot longer as im only using one chanel?
http://www.aaroncake.net/circuits/amp20w.htm
http://www.reconnsworld.com/audio_16wattamp.html
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4834
Alun
The first one is stereo not mono, and all of these projects are probably far too loud for you, a 1W amplifier made with the TDA7052  should be more than loud enough.
audioguru2
Apr 6, 2004
12,022
Hi Stuee,
100W would scare away the fish and anyone about 1km away. You need only a few watts for background music when fishing.
Most amps you posted are designed for 4 ohm speakers and therefore have double the idle current of an amp designed for 8 ohm speakers. The stereo ones have double the idle current again for the channel that is wasted.
The "20W" amp will provide about 4.5W at clipping into an 8 ohm speaker. Its max idle current will consume 2.1W.
The 2nd amp will be about the same except its LM383 ICs haven't been produced for many years.
The 3rd amp uses a surface-mount IC with umpteen number of pins (64) and you will probably be able to hear its distortion at high frequencies.
Maybe Alun's 1W amp won't be loud enough.
Years ago I made portable dual mono amplifiers to take to the beach. They gave a few watts output when powered by 6 AA Ni-Cad rechargable cells all day long. Now with modern Ni-MH cells they play all weekend.
Unfortunately the amp ICs aren't made anymore but Philips has a similar one, their TDA8945S. It has only 9 pins in a row with a heatsink tab. It will supply about 5W into an 8 ohm speaker (it can't drive 4 ohms) at clipping with a 12V battery. and its max idle current wastes only 0.4W. ;D
stuee
May 7, 2004
183
what type of battery would you reccomend. i might go for the philips amp. I was thinking of getting a spotlight torch and using the mini car batery out of that but finding a 12 is awkward most are 6v or 9v or could i use a load of recharge D batteries so i can stick the solar panel onto it so it keeps them topped up?
Thanks for your help so far. \
Stu
audioguru2
Apr 6, 2004
12,022
Hi Stuee,
If you look closely at the spec's for Energizer's AA and D Ni-MH rechargable cells, you will notice that they are exactly the same capacity. Their D cell is simply an AA cell in a big D-size can! ;D
hamoodyjamal
Jun 15, 2005
74
I have a simple solution for you. However, it does not include a Solar-cell to charge the battery.
I have done this 3 times and worked great!
All you need are some simple desktop speakers, and a rechargeable battery (or you can use normal batteries). The thing is, most simple desktop speakers (ones used for computers) have a built in transformer to drop the voltage to say 12V (in my case, it was always 9V with my speakers). So, you can hack through the transformer and connect the battery as the power supply, your speakers should work and become portable. They provide some what enough power for background music. About 5W.
I used a single 9V rechargeable battery rated 170mAh and it lasted a couple of hours on full charge. However, your speakers may need more/less than 9V (i.e. 6V or 12V ...) you will need to measure the o/p of the transformer. You will, however, get a higher reading than what it is actually. Mine measured 15V when it was actually 9V. I think the 15V is called RMS volts. I don’t know of a specific way to measure the actual voltage, but you can try by playing something and setting the speakers on the loudest. WARNING: YOU WILL BE DEALING WITH 220V SO BE VERY CAREFULL NOT TO TOUCH THE TRANSFORMER INPUT WIRES
My point is that you can use a battery to power simple desktop speakers. You may be wondering what I mean by simple, well, speakers that have minimal knobs, i.e. volume and power. This way, you won’t have to go through the trouble of building a circuit then housing it.
Hope that helps.
;D
audioguru2
Apr 6, 2004
12,022
Hi Hamoodyjamal,
You have a good idea to use computer self-powered speakers. My new computer came with pretty good-sounding speakers that are powered by a 12VDC/1A wall-wart.
I took one apart now and it has a 3" (77mm) 4 ohm speaker that is very heavy and has the biggest magnet I've seen on such a little speaker.
The circuit has a ST Micro 11-pin stereo amp IC that must be a house number because it doesn't exist on their website. They have other similar amp ICs like their TDA2009A that produces 3W per channel at clipping with my speaker's setup.
Its max idle current is 120mA so it would take a pretty big battery to power it over a weekend. ;D
stuee
May 7, 2004
183
thanks for the idea. i do have a few ideas and this was one but the speaker system i have here available is a 9v with a sub and 2 l/r speakers i might still go ahead. I was also thinking i might use a
Alarmclock. So i can have the Time, RADIO and also make a line to add on a mp3 player if i want to listen to custom speakers.
I have just purchased a bigish 12v battery rated  12v-18AH/20hr also a 4.5mw 14v solar panel, i did a few calculations ish  and i figure if i dont hammer the music loud i would be able to use the power from the battery for around 10hrs without any charging. But with the solar perm connected it should be fine. I will aslo add a cigarette socket to the box so in my tent i can plug a lamp into it also the airbed pump.
Any ideas now for the music source. I would prefer digital radio not analouge dials. also as here in aus when you go inland abit signals are a little crap to pick up so io might have to make a preamp if its possible.
audioguru2
Apr 6, 2004
12,022
Hi Stuee,
If you get a clock radio, get a good one (most are crap) and with an LCD display, since an LED display uses a lot of current continuously. ;D
