Can current flow in both directions through a JFET channel?
I am beginning to study JFETs . I want to limit this discussion to N
channel JFETs and when I talk about current flow I mean conventional
current flow.
Most of the sources that I have been studying use example where the
gate-source junction is reversed biased and the voltage at the drain
is positive with respect to the source and current flows from drain to
source.
What if the gate-source junction is still reversed biased and the
voltage at the drain is negative with respect to the source. Will
current now flow from the source to the drain?
I have also read somewhere that on "some" JFETs, the source and drain
connections are interchangeable while on others they are not. Is this
true? If so, how do you know which ones will do this?
Any help would be greatly appreciated. Thanks
Jamie
current flow.
source.
Your answers are there.
Scroll down and you'll see "Analog Switch"
http://www.interfet.com/pdf/App_Notes.pdf
http://webpages.charter.net/jamie_5"
Eeyore
current flow.
The answer is YES, at least up to a point since if you go too far it
starts distorting and I'm not interested past that point.
Think of it vaguely as a voltage controlled resistor.
Graham
Paul E. Schoen
That is a good app note. I have used JFETs (2N3819) in audio amplifiers I
made around 1970, and also as a voltage controlled resistance in a
programmable gain amplifier in a product I designed in the early 1980s.
This particular device is still available and can be very useful. I'm
fairly sure that the source and drain can be reversed, especially in low
signal level applications.
Another good app note, from Motorola, is:
http://rfwireless.rell.com/pdfs/AN_211A_D.pdf
Paul
Eeyore
Paul E. Schoen said:
I'm fairly sure that the source and drain can be reversed, especially in low
That's true of many jfet devices in fact.
Graham
Jamie
Paul
That's a very interesting PDF, I just briefly looked it over and there
is an assert on a subject that I had an argument once, with one of my
colleague's at work.. Not that it means anything now but I think it'll
be interesting to see the look on his face when he reads it because I
lost that battle with lack of documentation to back it up and since he's
the senior man, he didn't need any documentation :);.
Thanks.
