Help identify power components
ukspawn
Feb 5, 2022
88
this is what i see reading what Kellys_Eye said.
Martaine2005
May 12, 2015
5,318
Yes, you are correct.
I wanted to make sure you understood that the common is very important here. Common and -12V = negative 12V. Common and +12V = positive 12V.
If you only used -12V and +12v you would have 24V.
AAs are 1.5V not 3V. So 8x1.5=12.
Martin
ukspawn
Feb 5, 2022
88
oh DUR. of course theyre 1.5 lol, i totally understand now lol
Sorry my bad
Martaine2005
May 12, 2015
5,318
FWIW, it makes no difference. The device will only use the current it needs.
Martin
ukspawn
Feb 5, 2022
88
Martin
Yes I thought so, Thanks.
In PC Builds we say go above what you need, so if you need about 500 watts then go for a ~800watt psu.
I dont think you need so much headroom in a component as 'static' as a DAC, i would assume its always the same voltage everywhere except the output voltage. its not even an amplifier, just a DAC and volume control basically. But I did wonder if using a higher rated would be better in terms of a 40 watt PSU is probably built to handle more heat and with more headroom, so running cooler = longer life... but then i considered efficiency and isnt there a sweet spot for PSU to operate efficiently...
Anyway, thanks. just thinking out loud, maybe its interesting
kellys_eye
Jun 25, 2010
6,512
Not quite. That will be 24V.
You forgot the 0V centre connection.
But I think you understand.
No, he didn't get it wrong - you misread his post and missed the bit where he stated the common connection would be ground....
to the OP - yes, with two 12V batteries connected as described the common point is the ground and the two 12V posts remaining will be + and - 12V.
kellys_eye
Jun 25, 2010
6,512
Please use either current limiting or place an inline fuse in the 12V rails - 2A fuses will suffice. FAilure to do so could result in massive damage if there is a short elsewhere in the circuit.
