The circuit is designed on a perforated board. However, it is compact in component placement. LTC3639 is very small, so very thin magnet wires (enameled copper wire with almost zero resistance) needed to be connected to its leads in order to be able to have them soldered to other components.
And, yes I have already read the datasheet for inductor selection. This is where it is mentioned to use torroid or shielded pot core in ferrite type inductor. I am having one torroid type inductor but I don't know its inductance value nor its core type.
PS: Looked at the circuit connections again and found a few stray metal pieces stuck between unconnected points. Removed them and now I notice a completely different behavior. When the cap voltage is 50 V and discharged through the LED and 82 ohm resistor, the current is limited to around 18 mA which is what I am looking for until the voltage drops to around 34 - 35 V when the current shoots up to 150 mA and stays that way till the cap is completely discharged. When it is again charged to around 30 - 31 V, it exhibits the same behavior when voltage reaches to 26 - 27 V. The similar behavior can be seen at different voltage levels in a different charge-discharge cycle. What is this strange behavior?
Thanks.
