BHARGAV SHANKHALPARA
- Nov 6, 2013
- 35
- Joined
- Nov 6, 2013
- Messages
- 35
Hello All..!!
I am working on project water level controller. in that for water level detection i used three sensors shown in image. which is made up of stainless steel as well as mild steel.
i am using three sensors, one at bottom of tank which work as common. second at middle of tank, and third is at top of tank. in bottom sensor (work as common) i give DC 5V.
When i get 5 volt in both middle and top sensor we assume it as full tank, when not getting 5v at middle and top i assume tank is empty.
my problem is that when we install system at our farm its working perfectly, but after a week its start malfunction. when we see sensors which we have installed at top tank, there is Caustic Corrosion around common sensor in which we give DC 5V. thats why its not working properly. after that i cleaned common sensors and connect again its working fine.
is there any solution by which we avoid this type of Caustic Corrosion around sensor....??
Please suggest solution
thank you..!!
thank you..!!
