Checking Mosfets
pier1
Aug 21, 2006
180
While checking the N Channel Mosfet. I put the multimeter in the Beep mode (continuity mode)
Probing the -ve probe at the Mosfet Drain (tab), the +ve probe at the Source pin - the multimeter reads 500+ ohms which is the body diode I think.
Then
Still probing the -Ve on the Drain
I touch the +ve probe on the gate for a moment and then probe it back on the source it shows a dead short.
I don't know why this happens. Any body knows about this, please share.
The mosfet I used is FDD13AN0 from Fairchild initially
I tried the same with the:
BUK919 from NXP
NTD5867NL and a couple more and all show the same.
Regards
Pier
audioguru2
Apr 6, 2004
12,022
Your multimeter turned on the Mosfet and charged the gate-source capacitance that kept it turned on. The gate-source has an extremely low leakage current so the gate charge might last for a fairly long time.
pier1
Aug 21, 2006
180
Thanks AG for the reply.
Any ways of measuring this gate charge ?
Regards,
Pier
Hero999
Oct 28, 2007
2,433
Why bother measuring it?
It's easier to read the datasheet.
zoro222
Sep 30, 2011
5
i agree with audioguru and if you touched the gate and -ve the part will read hi resistance
