The Chinese kit had a 5V1 Zener diode for D7 since it used TL081 opamps. The new opamps use two diodes in series instead. A Zener diode is used with reverse polarity but you installed the two diodes backwards also with reverse polarity. Reverse the two diodes so that their cathode ends are at the negative voltage and they will limit the voltage to -1.3V. On a multimeter a 1N4148 diode should measure 0.6V to 0.7V on Diode Test, your "894" is too high.
